New member here. I have a 2019 PHEV, production date 11/18 that I bought totaled from an auction in 2020 with 5,000 miles on it. It had minor front damage to the front passenger-side quarter. No warranties/recourse, etc. I have the car on the road under a rebuilt title now and my wife had put over 10,000 miles on it in the past two years, with no real issues. There is an engine cylinder 3 (lean) misfire code that comes and goes, which based on TSB 212, indicated a new cylinder head may be needed. I've done some playing around to see if I could eliminate that misfire with periodic success, but this car doesn't really merit a new head at this time (that I would have to buy and install) based on how smoothly it runs. I work in a mechanical building trade for a living and wrenching on cars is a hobby. I bought this PHEV because I was looking to get into working/understanding electrified cars and get my wife something that was a little newer. She has a 5 mile commute to work so this car is perfect. My only complaint is that the engineering to make the AC a heat pump is relatively minor, so it doesn't make sense to need to use the ICE just for cabin heat.
Right now I'm having a battery drain issue that has me (temporarily, I hope) stumped. Last week, on Thursday, my wife went to start the car (she leaves it unlocked - we live in rural Maine) and nothing happened. I figured out pretty quickly that the 12V lead acid battery in the trunk was dead (about 5.5volts). I sent her on her way in the GMC pickup truck (which gets 10mpg, ugh) and put the charger on that battery. I did some reading and found here that the 12V battery is generally pretty short-lived. I also know that when I bought this car, it had sat through most of a winter at the auction yard with an almost dead battery. The day I picked up the car it started on its own - the next day when I went to drive it off the trailer it wouldn't start, so I figured out pretty quickly how that 12V battery operates (and that you could "jump start" this car with a lawnmower battery). So I believed that the most likely issue was the battery needing replacement.
I went to Autozone to buy a battery. I find a lot of their parts to be junk, but their Duralast batteries have been good to me. FYI nothing shows up in their computer for the PHEV 12v batteries - the battery size is a T4/ Group 99R. Autozone likes to tie battery searches to a specific car, so if you have them pick a Niro EV from the "Kia Trucks" list the 12V battery you need will come up.
I topped up the battery on Friday and installed it Friday night. We drove the car around all weekend three or four short trips, thought nothing of it (had family in town, had it in the back of my mind to check voltage but didn't remember to do it). I had a spare topped up 12V battery in the trunk in case I needed an emergency start, but didn't need it. Monday (yesterday) morning, she goes to start the car and nothing again. I check the voltage, and it's down to 5.5V again.
Now I know I have a draw or failure to charge issue. I charged the battery again yesterday and did some basic tests - headlights on, yep charging. Checked every mini fuse with voltage drop tests, pulled and tested every cartridge fuse. No apparent issues there. I was going to start looking at the multi-fuses but didn't get that far.
I got two new multimeters last night to do some current testing. None of the meters I had on hand took reliable DC current readings (anymore). I let the car sit in sleep mode (latches locked, one hour rest) and tested the draw. Under 50mA, no parasitic draw happening, which rules out the rear door latches found in TSB 163 for earlier models than mine.
I'm still stumped and gave up after two days of playing around. I put a battery kill switch on the 12V battery and went over the new routine with my wife - drive with headlights on, charge car (we do 120V charging), disconnect charge cord and kill the battery switch overnight. The only pain in the butt is leaning over the rear seat in the morning to switch the 12V battery back on, but we can deal with that for now.
I've ordered a bluetooth battery voltage monitor and a cigarette lighter USB/volt meter so I can see when the voltage draw is occurring. I did read on the Ioniq forum that one member there had an infotainment center that caused a similar huge draw, but pulling the dash apart is going to be the last thing I want to do unless I have to. I don't know how much the draw is, but to toast a fully charged battery it has to be at least 1Ah per hour so I'm looking for a sizeable draw.
I'll keep this post updated when I figure out more.
