So while other countries get a switch to turn off the incredibly loud reverse chime, and all of VESS, we in the US do not have this option.
Economies of scale being what they are, Kia did not make a different wiring harness for the US cars, so it turns out the wires extend all the way to the 'crash pad' switch assembly, although there is no switch. By examining the factory wiring diagrams, there is a blue with a black stripe wire that runs to the connector that when momentarily grounded, disables the VESS system, until you push it again or turn the vehicle off and on again.
I will put the wiring diagrams at the end as they are only for understanding what is happening.
First you need to pull the crash pad switch panel out.
To do this you need to start with the door aperture trim panel, which will pop out with a trim tool or carefully with a screwdriver. It is retained by the door seal, but you can leave it tucked in
The two screws seen here backed out need to be removed. The lower panel that contains the fuse box door can be pulled out and down without totally removing it. Then the switch panel can be pulled out, you can get some purchase with your fingers between the steering column area. If you haven't removed newer car trim, it takes a good pull but do be a bit careful
