The 5-button switch in the picture above is reference number 93700G5 from wrecked vehicle vin KNACD81DGL5412696Yes, for the 4 button. Looking for the one with 5 as in the photo.
Where did you find those photos? I found this part number BP7697604E3.Hey all, so European switch panels seem to have the same pinout and function regardless of button location. They are 100% plug and play with the US cars. All functions work correctly regardless of button position. The only thing that doesn't work is the headlight height adjuster wheel since that isn't supported in the US. The scroll wheel just doesn't do anything. Please note, some Niros have 4 button slots and some have 5. Make sure you get one that fits in the same dash hole (same number of button slots.)
View attachment 7519 View attachment 7520
Now you need to add a momentary switch across these two points. Those red plugs will accept a 1/4 MALE quick disconnect, not the more common female
McMaster-Carr
You can wire it differently, this is how I chose to do it. View attachment 6845
I would stop tapping the wires and switch in a European crash pad so it works as intended without modifying wiring.enirogus - I did the temp vess kill switch as you described and it has worked well for close to a year. In the last couple months, it intermittently fails to work. I suspect the T-tap guillotine type connectors (same as you show in your photos) are the culprit. Before I tear it all apart again, I am wondering if you've had anything you've learned since last year, that you might do differently. Also wondering if you've had any intermittent vess kill switch failures such as I've had. Thanks.
I have had no problems. First thing I would look at is the switch, easiest to checkenirogus - I did the temp vess kill switch as you described and it has worked well for close to a year. In the last couple months, it intermittently fails to work. I suspect the T-tap guillotine type connectors (same as you show in your photos) are the culprit. Before I tear it all apart again, I am wondering if you've had anything you've learned since last year, that you might do differently. Also wondering if you've had any intermittent vess kill switch failures such as I've had. Thanks.
The problem is that they are pretty expensive, and you most likely need a valid VIN to buy one.I would stop tapping the wires and switch in a European crash pad so it works as intended without modifying wiring.
Can you point me to where one might find the correct European crash pad for the 2020 Niro hybrid?I would stop tapping the wires and switch in a European crash pad so it works as intended without modifying wiring.
When I did the VESS kill, I soldered to the wires instead of using taps. I mostly followed the instructions at 2020 Kia E-Niro VESS/Reverse Chime defeat solution. You need to subscribe to the forum to download the pdf file instructions. I posted my minor changes to this procedure at 2020 Kia E-Niro VESS/Reverse Chime defeat solutionenirogus - I did the temp vess kill switch as you described and it has worked well for close to a year. In the last couple months, it intermittently fails to work. I suspect the T-tap guillotine type connectors (same as you show in your photos) are the culprit. Before I tear it all apart again, I am wondering if you've had anything you've learned since last year, that you might do differently. Also wondering if you've had any intermittent vess kill switch failures such as I've had. Thanks.
How do you remove the US panel in order to install the European panel with the VESS button? I found the 5 button I need here: KIA 93700-G5EG0WK / 93700G5EG0WK NIRO 2018 Controller/switchesHey all, so European switch panels seem to have the same pinout and function regardless of button location. They are 100% plug and play with the US cars. All functions work correctly regardless of button position. The only thing that doesn't work is the headlight height adjuster wheel since that isn't supported in the US. The scroll wheel just doesn't do anything.
That switch doesn't have a VESS button so it won't help you. You need to buy one with a VESS button.How do you remove the US panel in order to install the European panel with the VESS button? I found the 5 button I need here: KIA 93700-G5EG0WK / 93700G5EG0WK NIRO 2018 Controller/switches
