The ODBII port is required, at least in the US, so it's going to be there somewhere. Seems silly they don't mount them in a reasonable location.
Yes, I'm here in the states in Oregon, typically we take our vehicles to DEQ every two years for inspections and renewals, no safety checks or smog. With EVs you just pay and they mail you your tags without having to go through DEQ, so maybe some manufacturers aren't concerned about its access as much. 🤷♂️The ODBII port is required, at least in the US, so it's going to be there somewhere. Seems silly they don't mount them in a reasonable location.
I am going to disagree with your assertion that it should be in that holder behind the fuse panel door.I have encountered some confusion with other '2023 Niro EV owners about where the OBD II port is. Many insurance companies use them to track and offer discounted rates, my insurance is pay by the mile so they need it for mileage tracking. I've heard the port is sometimes not installed out of the factory, although it's there, just rolled up and taped behind the drivers side fuse panel. Others KIA models have it installed inside the driver side fuse panel facing outward, which means you have to have the cover off to fit a tracker.
My Niro OBD2 port was installed, but it was under the drive side fuse panel at the bottom edge of the dashboard facing downward, the port slot in the fuse panel was empty. Easy to miss if you don't look under the dashboard. Thankfully this location is much better as it allows the tracker to be installed facing downward and out of the way. It'd drive me crazy if I had to leave the fuse panel cover off.
Here's a KIA Optima ... and another in a different location, but facing forward. A quick search online shows a lot of cars with the port in the fuse panel facing forwards.I am going to disagree with your assertion that it should be in that holder behind the fuse panel door.
Where yours is located is exactly where my 2020 HEV is located and that is where they must be.
Regulations say you should not have to remove a cover to access the OBDII
Facing forward like the 2nd pic is quite common but I don't think that is an OBDII connectorHere's a KIA Optima ... and another in a different location, but facing forward. A quick search online shows a lot of cars with the port in the fuse panel facing forwards.
I'm not disagreeing with you about placement, just saying it's not always where it should be. The guy I talked to who bought the same KIA I did was using a 16 pin tracker and was driving around with the fuse panel cover off because it was installed in the empty slot I pointed to. He was going to have a mechanic move it to where mine is underneath.Facing forward like the 2nd pic is quite common but I don't think that is an OBDII connector
The 1st pic does not look like an OBDII connector
I don't think any of those pics is an OBDII connector
It is not normal to have to remove a cover to access OBDII
Nope, Pic 1 is definitely not OBDIII'm not disagreeing with you about placement, just saying it's not always where it should be. The guy I talked to who bought the same KIA I did was using a 16 pin tracker and was driving around with the fuse panel cover off because it was installed in the empty slot I pointed to. He was going to have a mechanic move it to where mine is underneath.
Pics 1 and 3 are definitely 16 pin OBD2 ports, you can see the shape of the cartridge, the first is just oriented upside down.
— Peace
