What mileage did you replace your brakes? I guess the title is a typo? 117k miles not 217k miles, right?117,333 miles on my 2017 Kia Niro replaced my brakes on all 4 wheels regular oil change when needed. Time for a new serpentine belt and I'll get another 100,000 miles...
Timing belt is the critical one, so you don't bend a valve.117,333 miles on my 2017 Kia Niro replaced my brakes on all 4 wheels regular oil change when needed. Time for a new serpentine belt and I'll get another 100,000 miles...
I think I recently read that these have timing chains. Is that correct? If so, for all modes?Timing belt is the critical one, so you don't bend a valve.
Yes, per the Kia parts buying list.I think I recently read that these have timing chains. Is that correct? If so, for all modes?
Timing belts are a thing of the past. Everything is now timing chain.Timing belt is the critical one, so you don't bend a valve.
What's old is new again!!!Timing belts are a thing of the past. Everything is now timing chain.
I use regenerative braking through the left paddle perhaps 80% of the time on a 2023 Niro SX. I looked at the front rotors last weekend. With ~2500 miles on the car, the cross-hatching from the factory machining was still visible. It's not hard to imagine pads lasting 100,000 miles.117,333 miles on my 2017 Kia Niro replaced my brakes on all 4 wheels regular oil change when needed. Time for a new serpentine belt and I'll get another 100,000 miles...
Give it some time and the "rust" will begin to appear unless you regularly cause the friction brakes to be applied.I use regenerative braking through the left paddle perhaps 80% of the time on a 2023 Niro SX. I looked at the front rotors last weekend. With ~2500 miles on the car, the cross-hatching from the factory machining was still visible. It's not hard to imagine pads lasting 100,000 miles.
Don't the friction brakes take over below 5 mph. or something like that? Or was that just a Prius thing?Give it some time and the "rust" will begin to appear unless you regularly cause the friction brakes to be applied.
I agree the brake pads will last a very long time.
Yes, they do but it will require more than that to keep the rotors clean.Don't the friction brakes take over below 5 mph. or something like that? Or was that just a Prius thing?
Does it say you have to drive the car to do this? Don't see what good it will do if the car is stationary? Seems overly complicated think it's easier to do what somebody else mentioned, just put the car in neutral and use the regular brakes to stop.
Yes, you would have to drive the car and it appears that they clean the rotors for approx 10 brake applications or less if you disable again. Shutting car off will return to default - regen.Does it say you have to drive the car to do this? Don't see what good it will do if the car is stationary? Seems overly complicated think it's easier to do what somebody else mentioned, just put the car in neutral and use the regular brakes to stop.
Is that a fact, across the mfr spectrum, I still see belts on spec sheets.Timing belts are a thing of the past. Everything is now timing chain.
I agree that chains make some maintenance issues a major procedure but those "maintenance issues" should not occur until high mileage is reached.Is that a fact, across the mfr spectrum, I still see belts on spec sheets.
Chains make straight forward maintenance issues, ie valve seals on a Camry, problematic.
