1 - 11 of 11 Posts
Just happened a few times but.............
Upon start up, first use of the day, summer weather and now cooler fall weather, when first accelerating from stop to slow roll, there's sometimes a "brake hum" as if the caliper hasn't fully disengaged? I'm not sure if that would be the case actually, just a guess here........... we DO use the parking brake 99% of the time, the 1% being when we forget to set it..... Niro EX, 3 months old, < 2,000 miles. Anyone else get this noise? Hoping it works itself out.
Remember, the brakes are really turning the generator to charge the HV battery. Mechanical brakes are only used after the system decides that the generators are no longer usable to slow the car down or the battery is full enough.
That hum could be the voltage inverter doing its job.
This isn't happening while breaking while the vehicle is in motion, it's when releasing the parking brake and beginning a slow roll out of our parking lot. It sounds as if the parking brake did not full disengage.
Hi I have the same problem with my new niro. How did you fix this noise? It’s in the garage and they don’t have a clue how to fix it. Thanks
I have noticed the same as eddarrah has said.
I use my parking brake most times as well, and it has happened a few times this summer, but since the cooler weather it has been more noticeable when starting to roll out the driveway after releasing the parking brake. I figure it 's the brakes or calipers sticking. I have heard the voltage inverter noise as well, but this is different.
I haven't been concerned over it, but I will certainly be listening for it next time I leave the driveway.
When I left this morning I released the park brake, turned off the radio and the climate control fan, rolled down the window and heard a loud snap or crack noise as I began to roll ... like the releasing of the brake pads that were froze to the rotors. It was quite a loud cracking sound!
Car had sat for 2 days in -5 Celsius temp.
If this continues, I'll have to notify the dealer. It can't be good on the brake system!
Discussion Starter #9
Brake Noise Update
Sorry I haven't posted in awhile...........
As temperatures get colder and colder here in Northern NY, I have noticed that this problem has disappeared. I think the Kia Niro Specialist mechanic at my local dealership was correct, when we were transitioning from late Summer to early - mid fall, the cooler morning temps resulted in condensation on the rotors which he says is normal for it to emit some noise during first movement............... we've now been ranging from teens to 20's temperature wise and the noise is gone. In a few days we will be getting from -5 below zero at night to single digits during the day................. off topic here but yes, SHORT trips KILL MPG!! have seen as low as 24mpg,,,,,,,,,,,however, I've also noticed on a few occasions of doing longer trips, that the mileage starts to go up quite a bit proportionately with the engine heating up. So far still loving this car, and now that we've had some snow, ice, slush conditions, with 4 snow tires, this car hasn't even skidded ONCE, used to get some skids with snow tires on other cars,,,,,,,,,,,I haven't even heard the anti lock brakes kick in yet in snow/ice/slush conditions,,,,,,,,,,,,with 4 snow tires this so far is the best car I have ever driven in harsh winter conditions!!
Discussion Starter #10
CB Bob;
I just had this happen yesterday!! First time!! We park outdoors and it's been in the high teens/low 20's over nights. We had some freezing rain, wet snow, icing all day on 12/23 and yesterday on 12/24 I heard the exact noise you described. I just figured it was the snow tires were a bit frozen to the ground, I've heard this before in other cars over the years,,,,,,,,,,,once rolling the car was fine.
Definitely a condensation issue on the rotors, as "eddarrah" has stated seems to be the issue! Not anything within our control, it's just the climate we live in.
Don't know if "semi-metallic" pads would alleviate this sticky issue ... any comments from technicians on this??
1 - 11 of 11 Posts
