Could you please tell where the cooler fan is located?
On the fan blades like a household fan. I doubt the fan comes on when the engine is running, there will be some temperature threshold trigger.Actually, the question is where is the electric motor of the cooling fan?
I can confirm that for the PHEV, the fan comes on in EV mode if the AC is on.Actually I think (somebody correct me if I'm wrong) most electric cooling fans also come on whenever the A/C is in operation. So when you start the car if the A/C is already on the electric cooling fan will come on right away. Right? Even if the ICE is off if the A/C is on the electric cooling fan will be on. Right?
That's right. Pretty much every car, whether traditional ICE, hybrid or EV with electric radiator fans will turn them on when the A/C is on. That's because it's important to have air flow through the A/C condenser in order for the system to operate correctly. This is especially true when stopped or at low speeds.Actually I think (somebody correct me if I'm wrong) most electric cooling fans also come on whenever the A/C is in operation. So when you start the car if the A/C is already on the electric cooling fan will come on right away. Right? Even if the ICE is off if the A/C is on the electric cooling fan will be on. Right?
