I DID purchase the whole shebang- front and back setups. Came in pretty quickly. Only problem is- there are NO instructions anywhere.* I tried to install the inside rear LEDs but couldn't get the casing open (oven didn't work to soften up sealant- there was none- it's glued/melted together), and quickly cracked the lens. (replacement on order). They do have a demo of one of their techs installing the LEDs in a headlight, and he used a melting iron (cutting iron, like a soldering iron, only hotter) to cut the back off, installed the LEDs and re-sealed the back by welding it back on with the iron. Gonna have to try that, but with a Dremel cutter. Pretty costly after all was said and done (Duties) and actual cost ended up being about 800 CDN. But it will look REALLY cool (I keep telling myself). I am determined to install them. I'm a pretty good technician, but I shouldn't have tried the baking thing. news/photos/video as it is being done.
*No information available as to how to remove fog lights, HEADLIGHTS, rear reflector. Hopefully I can do this without removing the bumpers... I even bought a couple of service manuals online, but not much step by step there.
