1 - 14 of 14 Posts
I am having problems finding the right spot for the dashcam I received for Christmas. It’s an Aukey and I’m using the suction cup mount so it is not as streamlined as ones that are just wedged shaped and mount right to the windshield. Since the Niro has the big housing in front of the rear view mirror, I can’t mount it so that it is partially hidden by the mirror. And if I mount it as close to the housing as I can, the housing partially blocks the view of the wide angle lens.
My best bet seems to be putting it on the passenger side next to the mirror so that it minimizes how much it blocks my view out the front and also minimizes how much the housing is blocking the camera’s view.
Got the 2 camera combo when I was doing Uber/Lyft because I also wanted to record inside the vehicle, then after about a year or so, noticed that that camera has "blanks" once a while in recordings, so decided to get a cheaper camera as a backup system. I do delivery in a busy neighborhood over 40 hours a week so I figure better insure myself
Discussion Starter · #6 ·
Ahh...that makes sense. I also just realized that I have to put on the Sunpass sticker on the windshield for the electronic tolls payments.
I've had mine professionally installed, but placed where I asked. The wires are all tucked away, and the rear cam looks even better than the front. I'm pretty tall, so the front placement was only as annoying as having all that bulky gear that's already attached.
Discussion Starter · #9 · (Edited)
Your set up looks really sweet. I was debating about getting a rear view camera as well but decided it was going to be too much of a pain to install the wiring.
I bought a base that attaches to the rear view mirror stalk so the the dashcam can be centered. I also bought the wiring kit so I can power it from the fuse box but I did not install it yet because it was getting late in the day and I didn’t want to do a rush job.
Here’s a screen capture from my camera. Since it’s attached to the mirror base, it is set back a bit from the windshield and the sensor base partially obscures the top of the camera. But that doesn’t seem to be too much of a factor. You can see from the pic that the traffic lights are still in full view which would be the main thing you would want to capture at the top if you were in a crash. Unless, of course, a helicopter landed on top of your car!
I have a front (Rexing 4k) and rear suction cup dash cam in my Niro, and they have already saved me from a traffic ticket and being charged my insurance deductible for a not-at-fault collision. The front one goes to the right of the mirror, and the USB cord I routed above the head liner and through the door frame seal into a console USB adapter. It's mounted on a modified toll responder mount with super glue. The rear cam wire has two USB extenders also plugged it the front console adapters, and the wire is hidden under the trunk, side seat and floor plastic parts.
Reactions: Nouseformonkeys
Discussion Starter · #11 ·
I wasn’t quite happy with the mount because it didn’t extend out far enough forward from the mirror to be able to clear the sensor housing, so bought a kit that allows the dashcam to extend lower and more forward. Here’s a screenshot with the adapter in place. Because the mount is longer than the original there’s a little bit of shaking in the video, but it’s not bad. Here’s a screenshot. The sensor base is no longer obscuring the top of the video.
I have a Seydi F1 dashcam that is small enough it is almost entirely hidden by the inside mirror, just a bit of the mount shows. Here I stuffed the wire up into the gap in the headliner and into the a-pillar cover w/o removing the cover. there was enough flex to push the wire into the gap by the windshield. Excess wire routed through the glove box. The 12v adapter has a USB port on the back.
Just a little update, I rerouted the wire by hiding it behind the rubber by the passenger door and under the plastic kick panel under the glovebox. I just tucked the wire into the gap at the front of the kick panel.
Discussion Starter · #14 ·
Much cleaner. It is not difficult to pull the rubber seal and pop the A-pillar cover so you can hide the cable under there. The only thing you have to worry about is to make sure the cable is not interfering with the rolled up airbag.
1 - 14 of 14 Posts
