1 - 12 of 12 Posts
Several times I have started the car (foot on brake, pressed start) and put it in reverse only to find that the gas pedal wouldn't work. The rear screen camera was on, and I believe the engine was on, but no power was given to the gas pedal. For the first time, yesterday, the same thing happened going forward. The engine was on, but the gas wasn't engaged and power steering wasn't on. The grade let the car roll forward and I could just barely muscle the steering wheel to control direction.
In all cases, turning the car off and restarting allowed normal functioning. This sounds like a computer and not a mechanical problem, but I'm curious if any other Niro's are suffering from this.
Ned
This happened to me two days ago! I have noticed some quirks, or maybe normal things that I'm not yet familiar with as we just purchased our Niro EX mid July. When you start the car in ACC mode only, NO engine, NO hybrid start, just ACC (accessory) mode to run radio etc. you get the intermittent warning regarding starting the car to prevent battery discharge...... (12v lithium portion battery that is, not hybrid battery), well, when driving, if you pull into a parking space, turn off the car, but do NOT exit the vehicle, it's like it goes into this ACC mode because the battery warning starts showing up on the dash screen (same screen as backup cam), opening and closing the driver side door while remaining in the driver seat solves this. I suspect that actually exiting the vehicle fully turns it off, but when I got back in the vehicle, I pressed start, with foot on brake, and everything lit up, I was on an upcline so rolled back while shifted into reverse but noticed the steering wheel was tight, the car was NOT on in drive mode!! I don't think this is actually a software bug with the vehicle but a sequencing error on my part. So far everything has worked great 99% of the time......... I may just have to get out the manual and read the basics lol, like how to start/stop the vehicle and what various deviations may trigger various issues. Also, it would be a good idea for those of us experiencing this quirk to be sure to look just under the gas/hybrid battery gauge on the dash behind the steering wheel, the little car icon, if it is lit up, the car is read to drive, if it's not on the car is NOT correctly started and/or ready to drive.
Ned
Ned- it sounds like you may have pressed the start when you weren't in park, or put in R or D before the scan was finished. I've done it myself a couple times. If you came out of park before it is finished "sweeping" or the scan it does when you start (with the little jingle), it's not started- just on. Bottom line, until it finishes the sweep(you must be in park the whole time), and you see the green car and arrow symbol, you can't drive off.
I am curious....how long does it take for the car to get ready to drive?
No more than 2 seconds. It takes longer to push the start button and reach for the shifter than it does to do the "scan" thing.
I tried going from my finger pushing the start button to drive or reverse, and it took about half a second. And I wasn't even in the "gotta get to work" mode. Each time it kept the green car and arrow from coming on. That is what happened a couple times when I first got the car, but hadn't figured out was the problem. Now I just push start first, and put on my seat belt. That gives the engine check sweep plenty of time. Plugging in phone, turning on radio/music, putting on sunglasses, etc. also gives it more than enough time.
I have seen a couple crazy things also.
Can't say exactly what I DID or DID NOT Do.
Like park in garage, hit turn off but did not go to park. Then it says go to park.
Seems like some times - I had to restart and then turn off.
Don't know, but convinced you have to do it right or it gets confused and so do I.
Guess starting to go has not been a problem as I typically do start and then put seat belt on (while in park).
Cars are safer now with all this interaction, but sometimes I wish for the simple days. I am 79 years old, so simple days are Long Ago. HA! Nearly back to straight shifts and for sure back to No Seat Belts.
1 - 12 of 12 Posts
