Hey all, I have a 2018 plugin. I'm pretty sure this is normal, but wanted to get other peoples takes. I noticed that in hybrid mode with the ICE on (not electric mode), when coasting in first gear at low speed, the engine seems to whirr loudly, even when I let off the throttle. It seems to have some inertia and sounds like it keeps 'going' even after letting go of the throttle. Does everyone else experience this? It's not a big deal and the car drives as I expect, but in city driving at low speeds it makes for an unsatisfying driving experience and sounds very much like the CVTs in the Prius I've tried to get away from.
It's not an issue if I just accelerate normally up through the higher gears, only if I'm crawling at very low speeds staying in first gear. It's sort of the equivalent sound/feeling as if I were in a manual and pressed in the clutch after accelerating in first gear, but kept my foot on the gas for an extra second or two. It seems like the car should be upshifting sooner.
