1 - 3 of 3 Posts
i read an article by a tesla owner (https://cleantechnica.com/2021/10/06/an-electric-vehicle-purchasing-handbook-chapter-1-charging/) who said that you can use the the standard 110V evse on a 220V line by simply using an adapter to mate the 110V plug with a 220V receptacle. does this work with the phev? the ev?
This is indeed true and I am doing just that on my PHEV. After my Kia charging cable stopped working after 3 years, I purchased a replacement that does just that. This 220V Level 2 charging cable comes with a 110V adapter that allows it to be used as a Level 1 charging cable in a 110V outlet. When I purchased it a little while ago it was $163.43 - a very good price. Now it's listed for $255.70 - considerably higher. It is 30-ft long and it's working well.
Post comment: I am not using a 110V cable for 220V service, rather a 220V cable for 110V service. I do not recommend doing that unless it's specifically rated for that service.
While it works, not all 120V EVSEs are rated for 240v. It depends on the quality of the internal components. I'd prefer using one that is rated for 240v. I never looked closely at the Niro's factory EVSE, as I only used it for the first couple of weeks until I set up a 240v EVSE.
And one last thing to consider is that the factory EVSE is only rated at 12 amps maximum. The Niro PHEV can accept 16 amps at 240v (33% higher), and the EV can accept 32 amps. The factory EVSE would be slower charging, even at 240v.
Reactions: Sstr Maria
1 - 3 of 3 Posts
