1 - 20 of 39 Posts
I went to open up the left passenger door on my 2017 Kia Niro and the handle popped out of the slot it inserts into. The exterior door handle cover broke at the location where the screw that holds it in place, threads. This small piece keeps the actual handle from slipping out of the slot in the doors that it inserts into, otherwise
the handle could just dangle, because the handle has play and can slide backwards if the cover is not there to stop it. I have read that other owners have had this cover break on them on any given door on the car. Because the cover is plastic and is held in place by a metal screw, torque may be an important factor in why the part fails. Kia agreed to fix the problem, but it has been three days so far, and it still hasn’t been replaced - part was not in stock at the dealership. When I initially took my car into the service department, the service tech told me that mine was the second Niro he had to fix with this problem that week. My curiosity makes me wonder if the fix involves an upgraded cover piece (and is done to each door) or if they just replace a poorly designed cover with the same type of cover. Hope Kia comes up with a real solution and not just a fix that might break again.
There are MANY posts on this forum regarding this issue, many are mine, as we had the problem too. It's not technically a "recall" but there was a TSB/Technical Serice Bulletin released by Kia regarding the issue..........apparently the door handles were over torqued by 30, quite a bit, and that is causing the problem............ your dealer should be aware of the TSB.......... it calls for replacing 3 door handles and NOT the driver side door..........when I inquired why not the driver door, the dealers response made perfect sense,,,,,,,,,,because that would involve also replacing the key lock and keys for that lock, making it a much more tedious "fix"............ I'm comfortable with their decision to "leave it be" until it's a problem,,,,,,,,,I've also read that Kia will cover this issue for the life of the vehicle, beyond any "warranties"...............so lifetime I guess.
Niro door handles.
I am currently driving a 2017 Kia Niro with one of the four door handles still attached. Three fell off in a 9 day period. I could not convince the dealer service department to order the parts without their technician seeing the Niro. So two trips in. The break is as described in other posts. It is hard to maintain confidence in a vehicle that has something so basic break. What will fall off next?
Small niggles like these are not limited to the Niro and even Honda has a few problems. At least they're willing to fix it outside of warranty.
Sorry to hear that your dealership is being annoying about it even though there's a TSB/Technical Serice Bulletin.
This should be a non issue now, there is a TSB (Technical Service Bulletin) that has been out since about September 2017 regarding the Niro door handles. The TSB calls for all door handles to be replaced EXCEPT the driver door, reason being that it has a keylock and replacing all keys and keylocks would be ridiculous at this point.....they will be replaced IF they break. ALL door handles are covered for the lifetime of the vehicle because of this issue,,,,,,,,,,,it WAS identified as an over torquing issue.......keep in mind that this is a TSB, NOT a recall, so you wont be recalled automatically,,,,,,,,, the fix is on a case by case basis,,,,,,,,,,our dealer had the 3 door handles in very quickly,,,,,,,the fix worked, no further door handles have broken off..........
Be happy this is a "trivial" defect caused by too much torque. You would be much more unhappy if the engine or transmission had a major defect. Or a safety defect causing a crash.
True 'dat ... but ... as others have noted, there is a TSB bulletin on this. Although an irritation, Kia US and Canada are well aware. I can only think that the demand for replacement door handles .. is large. Parts guy figures they have to come from Korea. And the way the dealer here has handled this .. disappointing. 3 trips so far. 1st trip .. dealer wanted to see the issue. Ok fair enough. 2n'd trip .. they have the part. Well not really, They ordered a rear hatch handle, even after having had seen the issue. Then I got a call on Tuesday this week telling me the part was in (well this was the booking centre I assume). So back to the dealer yesterday. Service advisor calls saying they don't have the part 30 minutes after I had left the car. Hmm strange, your dealership had called me 2 days earlier saying the part was in. Well, even he was pretty disgusted. Now I live fairly close to the dealership I go to (5 miles .. 7 km) but 3 useless trips .. rearranging schedules .. only to find out the part is not available right now. So a minor issue can easily become some a heck of a lot more irritating.
But true .. I have read some other major issues on this forum, this one is comparatively minor and I would even say, issues like this can be expected in the 1st production year of a new vehicle. But ****, I would just like it fixed
Not to deminish the issues that people are having with their door handles, but I am amazed that with the number of cell phones out there that nobody had the piece of mind to actually take a photograph of what happend and what condition the car door was left in post breakage.
Looking at the part failure, it looks like the plastic is just too britle for the application it is being used for. The platic bit does get force exerted on it every time you pull open the door handle. This is causing a stress fracture along the platic screw joint. Sadly there is a minimal amount of material around the bolt hole and it will likely keep on failing. The sad part to it comes down to cost verses loss of reputation. It costs Kia likely less than a penny to make that part out of pastic. To make it not fail would require them to make not only changes to the plastic part, but enlarge the hole in the door that the plastic boss fits into where it is bolted. If they made the boss out of metal it would cost them significantly more money to make the part.
Here is where the kicker comes in. If you didn't pull on the door handle quite as hard, then the plastic piece would likely not break as often if at all. So they look at it as the cost of fixing the problem that only effect a small number of people who pull the door handle too hard is far more expensive than just doing nothing and sending that $0.01 part out to a dealer to replace for the next 3 years. After that point they will say its not covered by any warranty and you'd get to eithe buy the plastic part for $15 or pay the dealer likely $65 to keep replacing it. As it's not a safely part they are under no obligation by any reglatory body to do anything to fix it.
Look at Ford with the Pinto gas tank. And that killed people. Have you tried complaining to the regional manager? Get in the face of people higher up the food chain and you might get something done about it.
Mine broke at the used dealers lot they ordered me a new one and I put it on. I also took the other 2 off and put epoxy on them so hopefully they last. My drivers side rear is the one that broke the passenger side rear was cracked and like I said I epoxied it. The front passenger was ok I just examined it and epoxied it and put it back. And backed off the drivers door nut a little.
82652-G5010 is the part number they are $10 each. Google that number and go to website and you'll find other colors. It's the cover left or right doesn't matter usually number 3 in the online diagram. I'd rather spend the $10 then sit at the dealer.
Or open the door and pop out the little grommet and back the nut off a hair that could help.
In a bizarre coincidence, I came to this forum to post a different issue, and felt that I should add to this thread, seeing as it's great to log these issues, so I posted my door handle issue (from last year) two posts above this. Anyways, the coincidence is that last night my passenger side door handle broke off last night. This one proved more difficult to temporarily put it back in place, as there is electric going to it (button/welcome light).
1 - 20 of 39 Posts
