I just purchased a used 2018 Niro EX. I am having a problem connecting my Pixel 4a phone via the USB port. When I plug in, I am not able to access Android Auto. The phone thinks it's charging for a half second, stops, buzzes again like it's charging, endlessly. No data transfer takes place and the USB options on the phone are never available, because the phone is not making a connection. This happens across many USB cables.
When I navigate to the Connections menu, I get a message "The setting cannot be changed while the USB device is connected. To change the setting please disconnect the USB device." So I disconnect device but the message persists. I have blown out with air and used a floss pick to clean USB port. There is no visible obstruction, and nothing appears bent or making contact. I attempted to reset to default, but I get the same message, that I can't perform reset while USB device is connected.
Has anyone experienced a similar problem?
Is there another USB port, aside from the middle console and below the head unit? Is there a way to perform a hard reset on my own? I am unfortunately very far from the dealership that I purchased from. I would like to be able to use Android Auto. I am able to connect phone and music playing features via Bluetooth.
Thanks for any suggestions!
