How to replace driver's side headlight in 2019 touring
639 Views 7 Replies 4 Participants Last post by  atc98092
How do I change the driver's side headlight? Unlike the passenger side, the driver's side has a "high voltage" metal object between the plastic headlight bulb compartment cover and the actual bulb. I can't find anything online showing this object (see picture).
Motor vehicle Hood Automotive design Car Vehicle
See less See more
1 - 8 of 8 Posts
I'm pretty sure the Touring trim for that year has LED headlights, and in most cases LED headlights are not user replaceable. Usually the entire light assembly has to be replaced. They also rarely fail. Depending on the mileage of your car, it might still be under warranty. Worth checking with a dealer to be certain.
Reactions: 2
Thank you for responding. I'll check with the dealer
actually Gen1 Touring has Xeon lights. just the bulb can be replace. with that note, failure of the bulb is not common as life span on Xeon bulbs are many times that of Halogen. but it's the twist off just like the halogen. Xeon has resister mounted on the bottom of the housing but picture shown does not look OEM. did you purchase your Niro used? if that is the case, you can either go back to Halogen [not Touring] or replace with aftermarket LED [P-n-p].
That surprises me. My PHEV top trim had LED lights, so I assumed the HEV had them as well. I wasn't expecting HIDs as the top when the PHEV and EV have LEDs.
My 19 touring in Canada has HID headlights .
My car is a magnat for bad drivers. I've had 2 separate collisions where someone has backed into the front of my car, and the repairs have been done at different shops in different states.
I'm only attempting to change the bulbs because after the most recent repairs, the passenger side bulb was noticeably less bright than the driver's side-enough so that I've been uncomfortable driving at night outside of any well-lit areas. I'm in Savannah where there are a lot of drunk tourists wandering around, and I prefer not to hit one.
I wanted to have bulbs of matching intensity. The shop that did the work was awful to deal with. I've posted some pretty excoriating reviews about them, so, I don't expect any help to remedy their crummy work. I may just stick with replacing the dim bulb for now, because I have no idea why the other one isn't OEM or which shop installed it. When I have a little more time I'll look through the receipts to see if I can figure out who put this in and why. If necessary, I'll reach out to my insurance adjuster for help.
See less See more
Probably the only way to do that is to replace both sides at once. And HID headlights are not cheap. I did a quick web search and found a page that listed two different headlight bulbs, both saying HID. However, one was labeled differently than the other, and I believe it was the true HID bulb. It showed an MSRP of $270 and a selling price of $200.
1 - 8 of 8 Posts
