Nope, big mistake by KIA.Is there nothing on the actual car? I have an app that I can use but I was hoping I have something on my dash or wherever in the car.
check the center display for the prev appIs there nothing on the actual car? I have an app that I can use but I was hoping I have something on my dash or wherever in the car.
It depends, on my EX Premium PHEV one of the instrument panel displays is an MPG indicator. It's just a horizontal bar indicator but it displays the current average mpg and the (instantaneous?) mpg is displayed graphically. Not perfect, but it works. In my experience the calculation of instantaneous mpg has a large uncertainty so the graph is good enough to tell me how I'm doing right now. The owner's manual implies that the feature is available on bot the regular and premium cluster. Here's the relevant page from the manual:Is there nothing on the actual car? I have an app that I can use but I was hoping I have something on my dash or wherever in the car.
That display only updates based on your manually resetting it. It does not average the current trip. That is probably the most useful bit of information, how am I doing during my trip...long or short.It depends, on my EX Premium PHEV one of the instrument panel displays is an MPG indicator. It's just a horizontal bar indicator but it displays the current average mpg and the (instantaneous?) mpg is displayed graphically. Not perfect, but it works. In my experience the calculation of instantaneous mpg has a large uncertainty so the graph is good enough to tell me how I'm doing right now. The owner's manual implies that the feature is available on bot the regular and premium cluster. Here's the relevant page from the manual:
I tried it this morning and while yes, the numeric display is the current average, the bar graph is the "instantaneous" value, kind of like the mpg meter in some older BMWs.That display only updates based on your manually resetting it. It does not average the current trip. That is probably the most useful bit of information, how am I doing during my trip...long or short.
Example...when I bought my Fusion Hybrid, I could tell when and where to coast or give power or regen based on comparing yesterdays trip with todays. My commute to work started at 39 mpg, by the time I traded it for the Niro, I was up to 44. Thats progress.
With the Niro, that just isnt easy or even possible. You will be guessing.
With the Ultragauge giving me current mpg feedback, I am actually getting better than EPA on mine. Heck, a trip to Walmart, that originally got 49 mpg, I can easily get up near 60...and that with a Touring model.
I have a standard hybrid, but it shouldnt matter. The Ultragauge gets its info from the OBD2 port and has a whole lot of readouts of that info. I used a binder clip and a couple of small screws and clipped it mounted to the thin piece of plastic right above the steering column.Question...on the Ultragauge...are you using it on a reg HEV or PHEV? and where did you mount it? Thanks!
Mike 2018 niro PHEV
When you turn off the car the dash center display (not the LED between the driver and passenger seat, but the middle of the dash) will show you your trip mpg (while it plays the turn off music). If you miss it you can turn on the instrument panel again in ACC mode and turn it off (I think... or worse case start and shut off the car).
The car has certain rules about when a “trip” resets. I forget the details but I think the car needs to be off for a few hours, do a shopping trip or perhaps even a movie/sporting event may count both ways as one trip.
Lastly the average MPG display can be configured to multiple modes... reset on fill-up, reset on new trip (I think) or reset never.
So between all those options that gives you an approximate instant read bar, a trip indicator and a last tank or indefinite indicator.
