1 - 20 of 22 Posts
It seems to me that whenever I have the HVAC system on, it seems to either want to heat the air or run the A/C. How can I get around this? Some times I just want to blow air in the cabin. I know the car always blows air in the cabin, but at a very low rate. Any recommendations?
Modern cars are user unfriendly. I would pay extra for old fashioned mechanical dials.
Here are your options. First, if you don't want air circulation, set the controls to recirculation (dedicated button), and then hit the Off button (also dedicated). It is my understanding that recirculation may cancel after a certain length of time because Koreans apparently believe fresh air is important to health. It will certainly reset after you turn the car off. As best I can tell, if you have set recirc and turned off HVAC, there is zero air circulation (previous cars I've had were leaky set this way at highway speed). You can also turn off the dash vents with the dial next to them. That way you can have circulation, but no air directed at you.
Next, if you do want unconditioned air flowing into the car, you must set the temperature to (about) the ambient air temperature (weren't old cars with red to blue dials easier?) displayed on your dash. Only then will the temperature not be adjusted.
One other quirk is that under some conditions, the auto defog system will turn on your AC without the AC light coming on to help dehumidify your interior space (specifically the windshield). If you don't like that, you can defeat it by pressing and holding the front "defrost" button. It has been over a year since I have done that, but as best I recall you will have then have an option to turn it off on the touchscreen. This option stays "sticky". Every time you turn the HVAC on thereafter, you will see a message on the top of the touchscreen informing you that ADS is off. Even with it off, you can certainly turn the AC on should you need it to defog your windshield. It may well be that if the AC is on with ADS working, heat will also come on so your interior temperature remains at the set temperature - not sure since I keep ADS off. But if that sounds like how you want it to operate, you will have to turn it back on.
It is all very complicated. Having this question come up again and again only demonstrates how far removed from user friendly interfaces car makers are. They are competing with the other car makers of course, and if you cannot set a "thermostat" in your car like your home, it won't seem like a modern system in the sales lot. I thought it was wild how perhaps forty years ago similar systems became available in luxury cars and thought at the time it was stupid. Quite sorry that they've finally trickled down to economy cars - I think in the last ten years. I can sort of understand the luxury frame of mind, set your temperature and never touch the controls again. But cars are not like homes, direct sunlight or shade totally screws things up and a simple dial makes it easy to find comfort when needed. I much prefer manual control.
Hear hear! This is the one "feature" of the Niro that I really don't like. It wouldn't be so bad if there was just a simple "Econ" button somewhere like in my '05 Audi. That prevents the A/C from coming on and you can just get fresh air in the cabin. Whether in "Auto" or otherwise it seems I can rarely find the perfect combination of settings so I'm always fiddling with it.
I found one workaround with mine. Turn the HVAC completely off, then tip the sunroof up (or crack open a window) just slightly. As long as you're moving you will get some unconditioned air flowing through the ductwork. No where near as functional as an "Econ" button, but it does work if you're moving.
I find that even if I set my preferred temp to the exterior temperature, the A/C is usually on. Put it 1 degree higher and the engine turns on to heat up the air! Maybe tipping the sunroof up is the best option, as it does flow more air. I normally either have the sunroof fully open or closed. And the noise is too loud for highway driving, but tipping it may be acceptable. Will check it out.
In our climate the outside temp is often around the temp you want to have inside. With the Climate control doing its work it will use minimal energy to maintain the set temperature. That could mean initially a bit heating and when it gets sunny a bit of cooling. On the EV there is a page on the central display telling you how much power the climate system is not using. It is minimal under these conditions. What is there not to like? You can focus on traffic instead of constantly fiddling with the dials? Or am I not understanding the problem?
@Pbodifee, it's really more of an issue with the PHEV, as enabling the HVAC is an immediate 2 mile range hit on them. Although real world range is still better than the EPA number, it's one way to squeeze a little extra range from the battery. And the PHEV doesn't have those extra power consumption screens. If I had the EV model, I wouldn't bother with it either. :)
That is a two mile hit on estimated range, not actual range. People really get upset by displayed guesses. You can change that display simply by turning off HVAC before plugging in, but that doesn't change actual battery capacity. How far you go in the real world depends on a lot of variables no matter what number is originally displayed. My HEV usually won't display over 530 miles when I fill the tank, yet I still manage to get 700 miles on a tank. The 530 mile guess is annoying, but doesn't change what I actually get.
Absolutely. But people see that immediate drop and it's in the back of their minds. How much in actually reduces range is, as you say, dependent on so many variables you can't place a hard number on it. But there should be no doubt that there is some sort of range impact.
Discussion Starter #11
If it's 19C outside and I want it 21C inside, and the A/C comes on and blasts cold air, I find that an inconvenience. I recently turned the A/C on and then off with a long press and it doesn't seem to be using the A/C now without me telling it too. Or maybe it's just a fluke and it's a bit more overcast and that is the difference...
On the EV switching HVAC on can be a 10 mile range hit! But hey, at 270+ miles range, who cares 0:)
I drive a 2019 Niro PHEV EX model. On this model if I turn the climate control off with the off push button and then push the fan button it is my impression I am getting unconditioned outside air. The grey bar at the top of the screen shows only the fan in black all other options are shown in grey. If I hit the A/C button the A/C icon changes from grey to black showing it is now on - if I push the A/C button again it goes back to grey showing it is off. Am I missing something?.
I hadn't tried that, but I'll look at it. It will be too hot when I leave work this afternoon, but I'll try it tomorrow morning on my morning commute.
I tried slightly opening a rear window this morning instead of tilting the sunroof up. Far, far noisier with the window even slightly open, so if you have a sunroof it's the quieter solution.
Discussion Starter #15
That is not what I've observed. Although that may be different now after I did the long press on the A/C to turn it off.
One thing to keep in mind when doing this is if you have the A/C or heat on and turn it off the coil that the air is passing through will still will have trapped latent energy and you will not get unconditioned air until all the retained heat or coolness in the coil has been dissipated by the incoming air.
Also some think that outside air is naturally fresh and invigorating. If you are trapped in traffic in the city on an 85 degree day the "fresh" air will be polluted super heated air from a city paved with asphalt mixing with the air from the cars exhaust in front of you then dragged across your hot hood into the ventilation duct to be sent to the passenger compartment of your car. I do realize most of you know this but I have run across individuals who thought "fresh" invigorating air would be magically drawn into the car in that environment!
Yes. If temperature is set above ambient temperature, your air will be heated. The fan button turns HVAC on.
Here is the button push sequence I use for the outside air ventilation only mode- 1. Climate off button 2. push the fan button to the desired speed 3. push the system circulation mode to face level only (for some reason this is important on my system - if I don't push this it will cool on the other positions I tried)
I use this in the morning when outside air temp is in the 70's and in the afternoon when the temps are in the low 90's and it works for me.
I forgot to include the ventilation mode step previously, the system target temp setting is at 74 degrees which we really never adjust. I do not notice any heating or cooling of the air doing this. Heating would be more apparent in the winter but I would think it would show the ICE coming on within the display with the associate noise of the ICE running.
edited for spelling
I tried it yesterday driving home. Even though the Auto light was off (since I had manually selected the fan speed) and the A/C icon was grayed out, the full HVAC was still running. It was 80F outside, and I definitely had cooled air coming from the vents. So I don't think that is actually working the way you expect. I was really hoping for some way to power the fan for air movement without engaging the HVAC cooling/heating system.
I did just now see you added setting the circulation mode as well. I didn't do that, so I'll give it another shot today. It's supposed to be in the 80s again, so I'll absolutely be able to tell if the air is being cooled.
1 - 20 of 22 Posts
