I installed a hitch on my Launch Edition today. It was very easy. The hitch is a Curt 13329. It has a 2" square receiver. The instructions are clear and easy to follow with one exception. They include a spring and wire for installing bolts into the frame rails. You wind the spring onto the bolt and fish it into a hole in the frame rail with a block to keep it from turning when you tighten the bolt. What they don't tell you is that the wire causes a problem when aligning the hitch. Take the wire off first and its much easier.
Other than that, its easy. The instructions state installation time of 45 minutes for a DIY installation and that is about right.
