1 - 6 of 6 Posts
Sorry if this seems like a dumb question, but I couldn't find the info I need in the owner's manual. Is it okay to just partially charge the battery if you just need to run a short errand, or is it best to only charge when you can fully charge?
Also, is it safe to charge when it's raining?
Thanks.
It's ok to charge up if going on a longer trip, but it's better to fully charge after a series of shorter trips.
I charge every day outside in my work lot, rain or shine. The plug is grounded.
Mine is always plugged in and charged to 100% every time. There's no setting to limit the SoC in the car, and Level 2 charging doesn't allow for the car to communicate that information to the EVSE, so there's no automated way to limit the level.
With a BEV it's best for long term health to limit at 80% the majority of the time. But PHEVs and BEVs have different sorts of draw and charge levels, so limiting the level isn't as critical with a PHEV.
Discussion Starter #4
So if I just need to run a short errand with a round trip of say 10 miles, just charging to say 60% isn't going to impact battery life or health in any way? I can see where I might want to do this from time to time, but if it somehow reduces battery capacity or longevity I won't do it.
No, in fact partial charging is better for lithium batteries. Ideally you want to keep the battery's state of charge between 20 and 80%. In the HEV, the tight programming keeps it between 40 and 60% 90% of the time. In a PHEV, or BEV, getting that last 10% charge not only takes a long time, uses relatively more energy than other percentage segments, but is also the most damaging to the battery. On many BEVs, charging over 80 or 90% requires an "Are you sure?" step. Ideally, you should only charge to 100% on days where you need the full range for the day's driving.
Mind you, there is a built in (hidden) buffer in the PHEV (and BEV) so truly charging to 100% doesn't actually happen, but the rationale still applies. Bottom line, don't worry about partial charging.
Discussion Starter #6
Thanks - very helpful info.
1 - 6 of 6 Posts
