What sort of mileage did you get in hybrid mode on the highway (not considering EV range)? And at what speed?I'm quite pleased with getting the extra miles. A/C was on for over 1/2 the trip since on highway (tollway) and with another passenger in car. .
When I noticed my engine go on, I was not technically on highway. was about 8 miles or so from my charging destination (near home). Was roughly driving 45 - 55 mph and flowing with traffic, but had several traffic signals I needed to stop at.What sort of mileage did you get in hybrid mode on the highway (not considering EV range)? And at what speed?
Even when running in HEV mode, on a long trip it is still slightly charging the battery, and recovery on downhills etc, will usually yield enough power it will kick into EV mode for portions on it's own.Man, those mileages beat even EPA numbers. Crazy that you can go that fast with the extra weight if the battery and still beat EPA numbers even after taking out battery range!
Is that not how HEV mode works in general for vehicles?Even when running in HEV mode, on a long trip it is still slightly charging the battery, and recovery on downhills etc, will usually yield enough power it will kick into EV mode for portions on it's own.
I was under the impression that the plain hybrid versions use the battery to assist the gas engine during normal driving, and sometimes solely move the vehicle while at low speeds. with the PHEV, it can turn the gas engine completely off and 100% drive the vehicle at highway speeds. It will do this even in HEV mode if it has enough charge to do so.Is that not how HEV mode works in general for vehicles?
Someone can correct me if I'm wrong, but I believe HEV-only cars typically do spurts of EV-only when they can. The difference is that PHEV electric motors are typically larger in addition to their larger traction battery, so they can both go much longer in EV-only mode, and go much faster in EV-only mode.I was under the impression that the plain hybrid versions use the battery to assist the gas engine during normal driving, and sometimes solely move the vehicle while at low speeds. with the PHEV, it can turn the gas engine completely off and 100% drive the vehicle at highway speeds. It will do this even in HEV mode if it has enough charge to do so.
The HEV only has a bit over 1 kWh of battery, and it also has a lower HP electric motor compared to the PHEV. I can keep my son-in-law's Ioniq HEV (identical powertrain to the Niro) in EV mode on the freeway when there's a slight downhill slope, but in general the engine will fire pretty quickly after pulling away from a stop sign in a residential area (so not accelerating hard). The only place I've been able to drive it solely with EV is in a flat parking lot that I'm not going much more than 5 MPH.Someone can correct me if I'm wrong, but I believe HEV-only cars typically do spurts of EV-only when they can. The difference is that PHEV electric motors are typically larger in addition to their larger traction battery, so they can both go much longer in EV-only mode, and go much faster in EV-only mode.
Those improvements in the 2023 are what I'm banking on. But I also live in the Midwest so I might be last in line to get one. The only things I'm disappointed about are the lack of 360-degree camera and blind spot camera. Potential lack of autodimming Homelink mirror also worries me.The HEV only has a bit over 1 kWh of battery, and it also has a lower HP electric motor compared to the PHEV. I can keep my son-in-law's Ioniq HEV (identical powertrain to the Niro) in EV mode on the freeway when there's a slight downhill slope, but in general the engine will fire pretty quickly after pulling away from a stop sign in a residential area (so not accelerating hard). The only place I've been able to drive it solely with EV is in a flat parking lot that I'm not going much more than 5 MPH.
The PHEV has almost 9 kWh in the battery (and getting more for 2023), and a little more powerful EV motor (it also is getting larger for '23), so it's capable of pure EV mode up to freeway speeds without an issue. You just have to keep the throttle foot light on the pedal, as there's a limit you pass that will still kick the ICE on if you press too hard. And on steep hills it can be next to impossible to not use the engine. With the improvements in the upcoming '23 PHEV, I might switch back from pure EV to a PHEV. Have to see what they're like in person.![]()
It's supposed to have an electric heater as well, so no need for the ICE to warm the cabin. I didn't have Homelink in my PHEV, and I don't have it in my Bolt now (but it did auto-dim in both). Yes, I'd prefer to have it. But I'm not overly concerned that I can't get it on these cars. I have gotten spoiled with the 360 camera in my Bolt, so perhaps Kia will have that as well. They haven't published a complete feature list yet. Hopefully they are getting close to their North America release. Probably be close to year end before any are actually available.Those improvements in the 2023 are what I'm banking on. But I also live in the Midwest so I might be last in line to get one. The only things I'm disappointed about are the lack of 360-degree camera and blind spot camera. Potential lack of autodimming Homelink mirror also worries me.
I appreciate your optimism. The reviews from Korea indicate I'd have to move up to the Sportage to get the 360 camera and blind spot camera...which would be OK if mileage at interstate speeds weren't comparatively garbage.It's supposed to have an electric heater as well, so no need for the ICE to warm the cabin. I didn't have Homelink in my PHEV, and I don't have it in my Bolt now (but it did auto-dim in both). Yes, I'd prefer to have it. But I'm not overly concerned that I can't get it on these cars. I have gotten spoiled with the 360 camera in my Bolt, so perhaps Kia will have that as well. They haven't published a complete feature list yet. Hopefully they are getting close to their North America release. Probably be close to year end before any are actually available.
My previous car was a 2010 Prius... there was a stretch I could go about 2 plus miles if I drove under 35 miles... took some carful managing since was not completely flat.Someone can correct me if I'm wrong, but I believe HEV-only cars typically do spurts of EV-only when they can. The difference is that PHEV electric motors are typically larger in addition to their larger traction battery, so they can both go much longer in EV-only mode, and go much faster in EV-only mode.
