1 - 16 of 16 Posts
has anyone so far replaced Kia Under Cover Splash Shield?
any advise appreciated.
thanks
Under Cover - Kia (29110-G5000)
kia niro ex 2017
6525
thanks
I haven't replaced it but I have taken it off before. It's really simple to remove and re-install, what advice are you looking for?
there are some cracks, holes on it,
maybe hit something on the road.
I guess I will need to remove and replace it.
this thing seems so simple but so expensive, more than $200.
I was looking for any previous experience,or advise about it
thanks alot.
Gotcha, it's a pretty complicated part with a bunch of aerodynamic elements and the access panels for oil filter and drain plug. Not surprised that it's kinda spendy.
Yeah, it is pretty expensive and complicated for something that is invisible and not really essential for operation of the vehicle. 20+ years ago no cars had these and they functioned just fine! I think the main purpose / function is to improve undercarriage aerodynamics and thus fuel efficiency. I have no idea if it ads 0.1 mpg or 3 mpg
If it were mine, I'd be wondering what actually harm, if any would result in not replacing the cracked shield.
I totally agree on all points. I would not replace it.
Having had a wife who badly damaged one on the previous vehicle... I can tell you that Gorilla tape won't hold long at all. The part isn't essential (at least wasn't on the 2013 Cmax) - but there is no doubt that without it there's a lot more road noise and less protection for the engine area where you have a lot of sensitive electronics. I didn't replace on the Cmax because I was pretty well ready to sell the car fairly soon anyways... but that was the only reason I didn't replace. I don't think $200 is out of line at all for such a large hunk of precision-engineered plastic.
The cover also most likely offers some improvement in aerodynamics, so MPG might be impacted.
That cover is there for aerodynamics only and if removed, the MPG change would be extremely small but no doubt measurable. I owned a 2012 Cruze that had plastic covering from the front bumper to the rear axle area. There was actually a recall to cut out part of the plastic under the engine because if the oil was splashed around on a change, it would hold dirt on the cover and with the turbo very close to that cover, fire was possible. I had a major section of that cover cut away and did not notice a change in MPG.
I hit something on the road with my Prius when it was fairly new and it happened real close to the Toyota dealer I did business with. Well dragging that thing caused a racket and everybody was looking when I drove into the service bay. I was gonna be late for work so I pleaded with them if they could fix it quick and a mechanic comes out with his knife, cut it off, threw it in the garbage and said it was a piece of you know what and wasn't necessary anyway. Problem solved, I drove it for another 150k mi. with no problem.
Gorilla tape doesn't work but there are methods to weld plastic back together. Depending on the cracks and the type of plastic, that might be possible in your case. If you're going to take it off and throw it away, might be worth a DIY attempt.
thanks
kia niro ex 2017
Hello, my undercover was practically ripped off when I decided to move over to the middle lane on a no light major road for an officer who had his flashing lights on about a mile down the road off on the shoulder to give him some space and when doing so I hit a tire in the middle of the road so once I had exited I heard it dragging so I pulled over to find it was only holding on by one clip so I removed the cover. So when I placed an order for a new one at a local dealership online only to find out that the item wasn’t in stock so after 4 different purchases I found out that the Kia Manufacturing Company is on back order and it could take 6 or more months and none local dealership will not ship this part because it’s to fragile which is understandable so the moral of the the store is that I’m now fabricating my original undercover with handmade aluminum bracelets so If anyone is interested you can reply and I’ll send you pics of the bracelets. The Fabricator…
Sure Fabricator, send me the pics of the bracelets. Anything to save paying $200 for a piece of sound proofing.
1 - 16 of 16 Posts
