Thanks to BWHIT for the first "How To Do Oil Change" and to HANOIHANCOCK for the Video on "How To Do Oil Change" cause it made it easier for me.
Not much I can add to their INFO -- maybe something here to help someone.
EASIER, but messed with it for about 3 Hours cause did not have the oil filter wrench size needed to take the original oil filter off (It's about 81MM size). After trying everything I could, I gave up and called the neighbor. He had the wrench, should have called earlier GROAN.
Anyway, the rest of the oil change was easy enough.
I use 2 x 8s (three stack) to get car up for access to the Filter and Darin Plug.
Take the Oil Fill Cap off to help the drain process.
As BWHIT stated, takes a 10MM socket to get the covers for the Oil Filter and the Drain Plug off. It's easy to take off the covers.
As BWHIT stated, it takes a 17MM socket for the drain plug. That thing was so tight I could not break it loose with about a foot long drive for the socket (laying under the car is not the best position to apply force to the wrench). I finally resorted to a breaker bar that was barely able to get on the socket and drain plug.
BTW, as someone else reported, pretty much took a wrench to get the drain plug out and back in. The threads are too tight for hand turning (almost thought the dang thing was cross threaded or something).
I had bought Oil (Valvoline Synthetic 5W-30 in a 5 quart container) for $21.98 plus tax, a FRAM TG9688 Filter for $8.99 plus tax, and a 75mm oil filter wrench for the FRAM Filter for $3.33 plus tax --- all at WALMART.
I tried about everything I could think of except to run a screwdriver thru the filter to get the Oil Filter off. FINALLY, called a neighbor that is into cars and he had a 81MM wrench that fit the original Oil Filter.
I did use a funnel to add oil and a rag around the area in case of a spill.
By the way, I recommend filling the new Oil Filter with oil (it takes awhile to fill it -- add oil and let it settle and add more). I also run a little new oil into the engine with the drain plug off to make sure all the old oil is out.
PICTURES - Pretty well show the rest of the process.
