1 - 18 of 18 Posts
I have mud flaps on my Niro PHEV EX. I really don't notice them with the aurora black color of the car. I still own a 1999 Hyundai Elantra with mud flaps and to date have never had a problem with any of them.
It seems the mud flaps install on top of the plastic cladding and not directly on the painted surfaces. However, if you did decide to take them off after a few years, you’d definitely see a difference in the color of the cladding and there might be some signs of wear.
I changed my backup lights a couple days ago and noted in the rear, there does not appear to be sheet metal outlining the wheel well. It seems to be a plastic fibrous sheet instead - flimsy and flexible, sort of a curved mudguard. I feel kind of foolish now for particular attention to the wheel wells trying to flush away winter salt.
I drove about 14 miles on a potholed gravel mountain road yesterday. There is quite a bit of dirt on the lower rocker panel and front door, but very little behind the rear wheels.
Two Question for anyone with mud flaps:
1. Do you still get lots of dirt and debris on the above areas or do the front MFs do a good job of reducing that?
2. If you got them as aftermarket, can they be installed without wheel removal? Did they impact your mpg?
Thanks
Administrator
Probably very little behind the rear wheels compared to the front is because these are front wheel drive, so all the back wheels do is keep the bumper from dragging on the ground. :D.
Yeah, I know. They do a tad more than that. ;) But that's likely the explanation.
Salesman I worked with bought me mud flaps and sent them to me. After I put them on I knew they would never come off. You will like them.
Were you able to install them with the tires on? How easy was the install?
yticolev: What back up lights did you install? Do you have a link? I'm still a bit apprehensive about LED backup lights since my PHEV started to throw some scary codes shortly after my installing my previous LED BU lights. No problems since I removed them but no one knows for sure how much if at all they contributed to the codes. :|
In this thread you have already replied to???
https://www.kianiroforum.com/forum/9-kia-niro-general-discussion/7013-reverse-light-bulb-change.html
Yes. and as of this eve, they are still listed as "Currently unavailable". Wish that were not the case as apparently several other Niro owners have these with no issues.
These look identical to the ones @yticolev purchased. My guess is some factory in China churned out a couple million of these and they are sold by various distributors. You could probably buy a container load on Alibaba for $1/ea. :D
https://www.amazon.com/dp/B0719CLLZK/ref=dp_cerb_1
Thanks
I had them thrown in on the deal, but dealer had to order them. I installed them-- very easy, there two metal screws you use vice the plastic push pins. No wheel removal needed. They are very low profile, only extending about one extra inch down and less wide. It noticeably keeps down some of the splash from the wheels, but of course not all. It doesn't affect the MPG at all.
<< - very easy, there two metal screws you use vice the plastic push pins. >>
I'm think something is missing in your sentence. Did you mean that you used two metal screws in place of the plastic push pins that are OEM? Thanks
1 - 18 of 18 Posts
