1 - 11 of 11 Posts
2018 Kia Niro PHEV, EX Premium
Good afternoon. I'm the new owner a 2018 Kia Niro PHEV EX Premium. I've been trying to update the navigation software. I went to the Kia site, then registered on the mapnsoft site, installed the navigation updater, downloaded the file to my hard drive then copied them on to an SD. All the files are in one main folder labeled NaU, then a secondary folder labeled 2018_20_Niro_Plug_in_Hybrid_USA . When but the card into the SD slot in the car, go the set up and click on update all I get is a message tell me it can't find any files. I've searched on this site, but can't seem to find a thread describing my difficulties. Any help would be greatly appreciated.
Thanks so much and I'm excited to join the Niro community,
Paul B.
The files cannot be located in a sub-folder. The secondary folder you have must be at the root of the drive.
So I should move the secondary folder out of the NaU folder, then delete the NaU folder?
It shouldn't be required to delete the NaU folder, since it's empty. But no need to retain it.
Discussion Starter · #5 ·
I attempted to install via SD card, and then USB to no avail. Just got a message that said “Insert the memory that contains the file and try again”.
I believe cars with an SD card cannot be updated via USB. It has to be done using the SD card. It's been a while since I did mine, but it was with the SD card. I tried USB and it didn't work.
Discussion Starter · #7 ·
Here is a pic of the folders and files that are in that 2018_20_Niro_Plug_in_Hybrid_USA folder. I can show whats in other folders as well. It seems different than what I've seen other threads so that's a bit confusing to me. Thoughts?
OK, I just found the SD card I used for my last update, and I see there is no folder at the root of the drive. Everything you have in that folder needs to be at the root of the card, no underlying folders.
It is after the small flap above the warning button (on my old MY2017 Niro, my actual MY2020 Niro does not have it, here it is done via USB):
6930
Reactions: lafe005
The SD card is only on older models like mine. Starting in 2020, they did away with the SD card and any updates are done through the USB port in the front console.
1 - 11 of 11 Posts
