What is NFCChargepoint also lets you use your phones' NFC as a card. So you tap the phone and it activates. Handy when there is no cell signal for the app. Many will also roam on each other's network, like in the old days of cell service.
Near-Field Communication. It's tech in many modern smart phones, used for very short-range (e.g. tap) data comms. If you have the Chargepoint app installed and your phone and OS supports NFC, you can lightly tap your phone on a spot on the station for authorization and to start a charge. I don't use that app+NFC method but understand it works the same as the free "tap to charge" card Chargepoint will send you on request. (Second and additional cards are $4.95/ea.)What is NFC
I find I can use my phone as NFC card with Chargepoint, EV connect (roaming as Chargepoint) and EA. Greenlots/Shell recharge requires their own.I think you can use the chargepoint or evgo cards at both stations, each one works with the other companies chargers. Having the rfid card does make it much easier, we had the CP card for our Niro PHEV to get free charging at all the same places and it's a lot quicker than using the app or NFC on a phone. Now we have an Ioniq 5 EV and the free charging is even more useful.
what do you do if the station is also outside of cell service?Unfortunately, I encounter many Chargepoint stations that have non-functional RIFD readers, so the app is the only way to activate those stations. And in every case I've encountered, they have been privately owned stations (not owned by Chargepoint themselves) so maintenance is questionable. I called the phone number listed on one of the stations more than a year ago, and nothing ever happened.
Fortunately, that was never a problem. But if there were no service, the charging stations would be unusable without the RFID scanner working.what do you do if the station is also outside of cell service?
