21 - 29 of 29 Posts
Not sure what model and trim you have, but I know on my 2017 HEV EX w tech package, the only instant mpg I’ve found is the bat, not a number.
Never tried the regular cruise control thing. I pulled out my manual though and although it does have a note which says “the system remembers the last selected mode”, that seems to be under the section about the fast/normal/slow responsiveness,
not the smart/regular setting.
Just took delivery of my 2018 Niro Premium and have a 2014 Prius 5 getting ready to be sold. So far I'm quite happy with my decision to switch although I have to say i really liked the Prius. So far the main difference is the amount of trunk space available in as I transferred my tools (sometime handyman) I quickly ran out of room in the back and inside as well. The Prius had many more cubby holes and besides the dual glove box the lower tray under the shifter assembly. As for build quality, it's a bit early to tell but the driving experience is better as is the switch from the NON slippery Toyota "pleather" to real leather is almost worth the switch.
My main reason for the switch is to get the EV range, the 10 yr warranty and I really like the styling of the Niro. Biggest disappointment so far - wheels are hubcaps and although they look quite real, it was not mentioned at any time during the purchase.
By the way I understand that there are alloy wheels under the hubcaps so will check them out.
So the advertising says! Not much objective data especially as I don't know that top tier gas is restricted to branded stations only. Lots of evidence otherwise about the supply chain.
Picked mine up end of Jan 2018. Manual is dated 2017. Oil recommendation is in section 9 page 7. Just the one oil choice.
More viscous oil certainly uses more energy, but you might not pick up the difference in mpg over two oil changes. Too many other independent variables. It is just one of those many small things that add up. I bought this car for its efficiency and I'd like to keep it efficient.
I used synthetic oil in my last car and kept religious records over 250,000 miles. Oil varied from 0W30 to 10W50. Couldn't tell any difference other than cold starts. But then my lifetime average in that vehicle was 28 mpg so small difference would be harder to pick up than a hybrid. But I know there was an efficiency difference even if I couldn't measure it.
that of course is not true. You have a range of oil choices. I can't imagine how you would not see that.
Discussion Starter · #26 ·
I just had a chance to drive a Gen.4 Prius in my role as a dealer swap driver. I've owned a few Gen 2&3 Prius but have never driven a Gen.4. I must say even though I really like the Prius I'm glad I switched to a Niro. I found the front seat room to be more roomy in the Niro. I thought they would be pretty similar but the Niro seemed roomier and my knees do not knock against the console in the Niro like they did in the Prius. The cabin (road noise seemed about the same.) I thought the Prius was quieter but I guess not.
I have the 2017 manual as well (PHEV version) so they're probably very similar if not identical in most respects. It's weird, you're right that page 9-7 lists 0W-20 as the sole recommendation but page 9-8 shows a range of allowable viscosities based on operating temperature. That lists 5W-20, 5W-30 and 10W-30 as compatible with the Niro. :confused:
Page 9-7
Text Font Line Design Number
Page 9-8
Text Font Line Parallel
I'd been driving the same 2005 model Prius from Nov 2004 through Nov 2017, at which point I traded it in for the Niro. I liked the CVT on the Prius -- it was smooth and responsive and never lacked for acceleration, in my experience. In comparison, the dual clutch transmission of the Niro is more choppy, with rough shifts and delayed engagement. This is the only unfavorable comparison to the Prius for me. Everything else about the Niro is an improvement over my 2005 Prius: the safety features and the interior finishes are quite an upgrade over the Prius. And most important, the Niro gets higher mpg, about 6 or 7 more mpg on average. I actually paid less for this Niro in 2017 than I did for the Prius back in 2004, yet the Niro is, in almost every way, clearly better.
We had the prius also , could only travel on battery for at the most a half mile, my 2017 ex I can travel all over town and not use any gas except for charging battery when using a/c have even been running on batteryonly on the highway at 65 mph, love our niro
21 - 29 of 29 Posts
