1 - 4 of 4 Posts
Hi,
The door handle came to apart as I opened the door. Has anyone else had this issue & does KIA have a recall bulletin on this problem ?
Yeah, this is a common issue on the Niros. Not sure if there is a bulletin, but it should be covered under warranty. It's a bit troubling that this keeps happening even to newer cars as you would have hoped that they would have fixed the problem by now. Knock wood, I've avoided this so far.
My dealer replaced 3 door handles (except for the driver's) under a warranty item when I took it in for service. You should inquire about it.
Here are the notations about it on my service record:
Op-Code: 180124R0
Type: Warranty
Description: SA361 DE Outside Door Handle Cover R&R
1 - 4 of 4 Posts
