1 - 20 of 21 Posts
Hi, I have a problem with the plug-in door of my Niro EV getting stuck. I have gone to the dealership 3 times already to get that reset again. I know I know - I need to make sure all car doors are unlocked before attempting to open the plugin charge door. I've followed all the instructions like a schoolboy. But it just keeps happening every few months. Getting tired of this and taking it to get things reset. Anyone else having that problem? I looked up a similar thread on this forum (post #50594) but his/her issue got fixed by making sure all main doors are unlocked. I haven't been that lucky. Any inputs?
What happens if you use the emergency release? Is the door flush, or slightly ajar?
The door was slightly ajar. But you are spot on Spiritwalker2222! When I took it to the dealership, they showed me the Emergency release which unlocked the stuck door. Interestingly enough it's very hard to replicate and it doesn't happen every time. Until it happens again on its whim, I am all set for now. thanks again!
my 2019 did the same thing twice and when taken to the dealer they said it was a program problem and they did some thing with the program and it has been fine ever sense
My phev dose this sometimes I found I have to lock and unlock the car so it will let me open the door hope this helps btw the door come off very easily as it just slide on the hinge
There's a button on the dash. It changes the way the lock works on the charge port. If it's on, you cannot unplug the charge cable if charging is occurring. But when the charge is complete you can disconnect the cable regardless of the door lock status. If the button is turned off, then the charge cable is locked to the car at all times until the car doors are unlocked. And if you don't unplug within a short time (perhaps a minute) it will relock.
This is intentional. If you're using your own EVSE, and you're somewhere out in public, you don't want someone unplugging your EVSE and walking off with it. But if you're using a public charger somewhere, you want someone to be able to unplug you once it's charged to let someone else use the charger.
I was having the same issue, but when I took it to the dealer, they replaced the mechanical piece inside the door. A few weeks later, its stuck again! Where is the emergency release? Hoping this will be a quick fix before I can get back to the dealer.
Discussion Starter · #8 ·
Discussion Starter · #9 ·
Scrow. Emergency release is located in the hood on the lower right side. Its Orange color plastic tab. You have to pull it. The owners manual shows this process too. I should’ve read it before I went to the dealership a few times! Hope that helps.
I assume you mean right hand side when standing at the front end. That's the left side of the car. :D
There seems to be a sequence you have to follow
1 switch off /unplug charger
2 open car door leave open
3 unplug lead
If it doesn't work lock doors and start again
I don't have a 7kW home charger yet so don't know how it would work if charge was incomplete & you can't switch off wall unit.
I had the same problem. Took the car to the dealer, they performed a software update. it worked for two days then went back to not working. Back to the dealer, this time to have the charge door lock mechanism replaced. The dealer ordered and installed the new part. This new part was defective! so the dealer ordered another new part, shipped overnight, installed and now seems to be operating correctly. Note: I was unable to make the emergency release work When my charge door lock failed
Fyi there was a recall for the charge cord. Bring it with when you service at the dealer. As far as I can tell the dealer just installed a rubber bumper cover over the charge cord box. Luvs me Niro
Just a reminder to change your cabin air filter for best AC performance.
Mine stuck for 1st time today. Emergency release worked 1st try. Fingers X ed that it is a one time episode, but previous post suggest I may have to visit the dealer.
Well, my gas tank door gets stuck sometimes so it's a universal problem. I just whack the door with my hand and it pops open. I think the solenoid that unlocks the door sticks.
Same issue. First time. Door wouldn't open. Had it "fixed" . Two days later, it wouldn't UNPLUG!!! So this time I had to get it towed to dealer. That was a month ago. Door won't open again. Came here Looking for the quick fix but pretty tired of this BS.
Does anyone know of a way to disable the lock altogether? My door is getting stuck (most of the time) and the charger is getting stuck because the car won't release it (most of the time). The emergency release will work but it is certainly a pain and something I don't feel I should have to do on a new car with a great warranty. I have taken it into the dealer and they can't replicate the issue. They just hit unlock on the key fob and everything was fine. I'm very frustrated. Does anyone know of a way to disable the locking feature? I only charge the car at home anyway...
I personally wouldn't want the door unlocked at all times. There are far too many people out there that think it's funny to vandalize vehicles, and plug-in cars seem to be an extra special target. My new Bolt doesn't lock the door and that's something I don't like.
I am fed up of the charger door getting stuck, I give it a few bangs and open and close and then after a while, I get lucky, Now what I do is when the door is open, I manually push the locking mechanism back and then close the door, without locking it, the alarm does not go off and at least I know i am not going to look stupid when I pull up at a charger and cant open the charger door. when it goes in for a service, I will tell them to check it out.
1 - 20 of 21 Posts
