My '22 EV gets better mileage on a charge as it gets warmer out.
That's exactly what happens with an EV. While ICE vehicles lose some range in colder weather, it doesn't approach the loss of range we see in our EVs. My Bolt is EPA rated about 240 miles, which would be 192 miles at 80% charge. Through the winter my 80% range went as low as the 150s, although as of today it's back to about 178. Using the electric heater is the biggest reason for the drain, although the battery itself loses a bit of capacity in cold weather. If your EV does not have a heat pump, the heater will draw between 7-8 kW to warm the cabin. Of course, it doesn't draw that much on a constant basis. I've seen mine drop down to 1-2 kW once the interior has some warmth to it. With it completely off, the car draws 1 kW or less when not moving.
If you need A/C when it gets warm out, it doesn't impact the EV range anywhere near like the heater does. Using the A/C you won't see more than 2-3 kW for max cooling, and usually it's near the same power draw as the car "idling". That's the advantage of the heat pump, in that it uses about the same power as the A/C draw but instead is giving you heat instead of cold. Of course, if it really gets cold there's still an electric heater to help out the heat pump, which loses efficiency when the temp gets to freezing or below.
