I have had myKia Niro for just shy of 2 weeks now. I was loving it but over the past few days it started to drive me nuts. I developed a rattle that just got worse and worse. I had a very hard time to figure it out. It sounded like it was coming from the pasenger side rear, but if you drove around sitting in that spot the noise just didn't occur. As soon as you sat in the front with the rear seats empty the rattle noise came back.
I thought it might have been the seat belts but I figured out there was a small slot that you can put them into so they wouldn't bang. Yet the sound continuded until I reaized that the actual seat top that you sit on was sort of a bit loose. You can lift it up about 1-2mm. If I put something heavy on the seat the noise goes away. Now I have to see if my dealership will take on fixing the problem. You can easily see that seat is loose, but no idea if this is something that will be easy to fix. I assume that the top is removable as isn't that where the batteries are located?
