1 - 5 of 5 Posts
My Schedule charge button on the left side of the steering wheel does nothing. Does this mean I dont have scheduled charging? I have an EX Plug in Hybrid. I set a schedule on the Kia Access app last night and it did not charge.
I believe if you set to only charge off peak, pushing the button innitates an immediate charge, regardless of the off peak settings.
If you happen to have a smart wall charger, those have the timing built into them. I have a Juicebox pro 40 and I use that timing on the app To have it start at 10 PM every night.
You need to set up the charging schedule with the central touch-screen menu. The button you are referring to is if you want to bypass your charging schedule and charge immediately. (Nevermind, I assume you've figured it out by now.)
1 - 5 of 5 Posts
