21 - 32 of 32 Posts
Installed the side window Sunshades. Mainly, I like to be able to leave the windows cracked when sitting out on a hot day and not have to worry about rain getting in.
Bought them off E-Bay (Korea Seller) for $49.75. Found out later there are better prices and my guess is as good a quality. SO SHOP more than I did. Takes a while for delivery as come from Korea.
They fit nicely and easy to install, but end up covering the Chrome at top edge of the door (Mine is EX Model).
No Instructions provided, so I give a couple pointers:
1) Clean surface of door (Chrome) with Alcohol and dry (at least that is what I did).
2) DO NOT REMOVE the backing from the tape completely. Remove about 3 or 4 inches and let it hang loose so you can pull it out a bit at a time as you fit the shades to the door.
NOTE 1: You would have a hard time aligning the entire shade at one time if you had the backing completely off the tape as it will stick to the door where you touch it.
NOTE 2: When doing the front door, I started with the tape loose about 4 inches at the door pillar end. Back door would work starting on either end, but I started at the pillar on back door also.
3) Mine had a small shade piece (about 10 inches long) for the side rear windows. Start it at the door opening.
NOTE: IMPORTANT - Make sure your rear door clears the shade when you open the door before you decide exactly where to stick it. You may need to sit it back a 1/16 or 1/32 from edge of the chrome to clear the rubber gasket on the door as you open the door. MY PASSENGER SIDE REAR DOOR rubber hit the shade after I installed it and I had to remove the shade and slide it back a little.
I think I lucked out and did not destroy the tape on the shade when I removed it.
4) One last comment (not an installation instruction) --- my shades came with a shield to put over the top of the side mirrors. I did not use it as it was a piece of junk (flexible rubber like material that sort of folded down and hides part of the mirror). Besides that, it would look cheap.
The shades do cover the door chrome at top of door, but still look nice (my opinion). Also, unlike my Nissan Rogue which had a visibility problem when turning left because of the pillar that got worse with the width of the shades, visibility seems OK with the NIRO.
The pictures taken in the garage are not too good Lighting - I took one with the garage light on and one with a flash). Maybe get a better one outside.
From what I've seen, the rear passenger windows are tinted so I don't know if I would bother putting deflectors on those, but the front doors don't appear tinted in the pics that I've seen.
Of course, it's nice having the window open a little even if it's raining.
I've had them on my last two vehicles and I really like them!
Why wouldn't you put window deflectors on rear windows because they are tinted?
Jpear,
I don't know what they are called --- all I know is see picture I took and posted when car was parked on a street as that is a clear picture of the "whatever you call them".
The main reason I LIKE them is -- You can leave window open an inch or so on hot days and not worry about a Pop Up Shower. The "Whatever" keeps the rain out. :)
I had tint added to my front windows (legal limit on darkness). It does not matter if windows are tinted or not.
First of all putting "whatevers" on just the front would look bad (my opinion). The "whatevers" are not for shade (my opinion). That said, they might help some if sun at a particular elevation.
As I said, my purpose is to keep windows open an inch or so on hot days and not worry about rain.
Well, it's waethertech and their stuff is generally pretty well fitting and effective. Though I've never tried their window visors, they're more known for floor mats.
No offence to anyone but this is crazy, so many people still using these? They make the car look ugly as ****. Does it even work?
In Florida I think that they are a must, during the summer months it will reduce inside temps by about 20 degrees, while keeping any rain showers out. If you have dark Tint on windows and get dark tinted Visors you hardly notice them.
I have had Weathertech side window deflectors on several car (Hondas, Dodge Caravan, VW Golf...). They fit into nicely into the window channel, no tape required. Personally I like the look and the ability have have the window open a bit without buffeting my head & reducing heat build up on hot days. With the windows down an inch or so, it is not noticable to casual passer bys. Personally have used them only on front windows and I like the look. I feel they have been a nice, solid addition to past cars.
Just looked on WeatherTech and they currently don't have any for Niros.
Some months ago, they did have them for the Niro. The rear windows down will be noticeable to casual observers as they also open on the vertical edge.
21 - 32 of 32 Posts
