Since the wheel type and the brake rotor size seems specific to the '23 EV, here's what I found as I took on my snow tire upgrade project.
Here's some numbers for the sizes.
Kia Niro 2023 EV.pdf
If you own the PHEV or the HEV, you'll want to check here for your offset numbers:
2023 Kia Niro - Wheel & Tire Sizes, PCD, Offset and Rims specs
With the help of the pro's at Tire Rack, we tried one wheel and tire setup for a "test" fit because Tire Rack had no info on the '23 new Niro.
I purchased (1) Bridgestone Blizzak 215/55/R17 tire, mounted and balanced, on a 17x7 (5-114 ET 42) steel wheel, with a Continental 433mhz TPMS sensor installed for a test.
-Tire #- 155HR7WS90001135 ($159.99)
-Wheel #- X42752 ($124.72)
-TPMS #- S1905523 ($48.00)
-5 Lug Nuts- (Free)
PERFECT !!
So I ordered another single tire setup. Keep in mind the factory wheel for the EV is an "odd" size and has an offset of 52. The closest I could find in a steel wheel with that offset is 42. A difference of about 10mm. So the tire will stick out a little from the fender well, and the best I could measure, is it sticks out about 7mm. You can buy expensive aluminum wheels with that 52 offset, but the 7mm stick out doesn't seem to be an issue for me.
You can just barely notice. Look around the red sticker on the tire. The other black in the picture is the plastic fender trim:
They drive just fine with only a little more road noise as expected with snows. We have had no winter so far this year, so I have no idea how the car performs in the snow, so I put the summer tires back on until it snows, if it snows this year.
The back of the factory wheel:
The TPMS................ I haven't figured that out yet. The manual says I have to go to the dealer to initialize the sensor, but I'm not going to do that, and I don't think that's the case. I think the Kia auto initializes. Some cars, you do it through the computer, some press a button, and some like GM, use a reset tool you have to buy.
On my 20 mile test drive, the TPMS light did not come on, but on the tire pressure dispaly screen, it never readout the tire pressures, and only said "Drive To Initialize." But no yellow TPMS idiot light.
On the other cars, I can't go 1 mile before the light comes on and I have to do a reset.
I need more testing on the Kia.
NOW............
Because the manual says NOT 1 word on jacking the vehicle, they want you to return to your "authorized Kia dealership", I think I'll post another thread on that subject. Since the battery hangs down so low on this car, don't let some tire jockey jack it up on that battery. It'll cost 'ya.
-5 Lug Nuts- (Free)
PERFECT !!
NOW............
