41 - 60 of 142 Posts
so I was talking to the service dept ,he sent Kia's statement ...PS 481 dual ...erisstics pdf ,has it been posted on this site ,how can I post a screen shot ? thanks ....
Mainly I feel that when gas engine is cold but also a little bit when hot. Do you think that it is related with injectors? I think I have not feel it from the beginning.
2017 Niro Stuttering and Hesitation an EGR System Problem
I have a 2017 Niro I bought in Louisiana in late November 2017. I was visiting Michigan when the recall notice came and I took the car to a dealership in Michigan for the work. Coincidentally, about that time, it developed the jerking and hesitation well described in Mitch Bowe post to this thread dated June 2018. The tech said that their dealerships had seen 3 other 2017 Niros with similar problems with the EGR system and had to replace the engines. This is what was done on Mitch's's car, so Kia is undoubtedly aware that some 2017s have this problem and that the only solution is engine replacement.
Because of how long it would take to get approval, the new engine, etc., the Michigan tech recommended that I have the work done in Louisiana. Well, it turns out that the dealership where I bought the car doesn't have a tech who is certified to work on hybrids -- even though they sell them. I have contacted two other area dealerships still with no luck. So, I may have to get the work done when I go back to Michigan later this year. I was assured by the Michigan tech that the problem wasn't something that would cause the engine to fail and leave me stranded by the side of the road. It is a performance problem. Still, getting onto busy the interstate when the car stutters and hesitates rather than accelerating properly is a bit tense.
I am hoping to get this problem resolved because I love the car.
Stuttering or Mis-Fire: I have a 2017 Niro Turing purchased in March of 2017. Around 8,000 miles I started experiencing the problem. I have noticed that I MPG has fallen from a normal 45/46 to 39/41 these past 2,000 miles or so. I now have 11,500 miles and it seems that the stuttering is getting worse and is becoming a problem. At my 10,000 mile service I made the dealer aware but they said it did not mis perform for them.
What are my best options at this point. I plan to set an appt with my dealer to have them drive and test. If some of you Senior members could address this issue with me it would be appreciated. TULSA. OK
EGR Valve problem may be why the car is shuttering
I have had by 2017 Kia Niro at the dealer for 3 months. 14K miles. Shutter was terrible. After interacting with the Kia TA Center in California, the dealer said the problem is with the EGR Valve (exhaust gas recirculation). They have put in a new short block engine, new head and replaced the EGR Valve. They say they are waiting for an EGR 'tube' on back order. I'm concerned about this fix and wonder if anyone else has had this and if it fixes the problem for good. Anyone???
This is what my dealer in Indiana has said the problem is. They have replaced the engine, with a short block, put in a new head and EGR valve. They are waiting on something they are calling an EGR tube on back order. Has anyone had this type of fix and does it actually work?
Update and RESOLUTION of the stutter problem!
I, too, have had the "stutter" problem on our '17 Niro EX...and our vehicle has now over 6500 miles on the odometer. The shuddering is very obvious when the Niro is right at the junction of coasting and needing a bit of acceleration to maintain speed. It feels just like a misfire (like someone pulled a plug wire on one of the cylinders) except the MPG's don't seem to be affected...as the car still averages over 52 mpg banging around town and mid-to-high 40's mpg on the highway. This jerking occurs in both EV and gas modes which , of course, leads one to believe it is not an engine misfire but perhaps a transmission/power train problem. Maybe the mechanism to provide a smooth transition between gas and EV modes is at fault?
The car has been twice to the dealer for this issue, but because no error codes get thrown by the OBD, they claim nothing can be done to remedy the problem. Supposedly, this complaint was registered by the dealership's repair facility in such a manner that ALL Kia maintenance personnel worldwide can see the problem and share remedies when available.
Follow-up to original post and resolution: Sept. 20, 2018--Our stuttering Niro was in the local dealership's repair facility for 71 days! During this time the air intake manifold was removed to determine castings numbers on the cylinder heads to rule out problems Kia was having with a certain heads that were installed in some engines. That not being the case with our Niro, the next suggestion from Kia Tech was to replace all of the fuel injectors, which did not rectify the stutter. Our local service department then drove the vehicle from a cold start with a computer attached...and discovered that when the EGR valves opened, all four cylinders reported misfires (yet no OBD code was thrown.) After replacing the EGR system, the stutter remained.....so it was decided that a new engine would be installed. And it was! (All of the attempts to repair the stumbling issue were directives from the parent Kia Service department...yet were futile.) Our 18K mile Niro now has a brand new engine...and is performing just fine. Kia provided us with a rental 2018 Altima (through Enterprise) for the duration of this repair, so any inconveniencing was minimal. (It should be noted here that my original description of the stutter problem was revised before bringing to the dealership: The stutter ONLY occurred from a COLD start....and lasted only until the engine warmed up. It did NOT appear when the engine was in EV mode.))
Hello All,
Following the post from JosephO - I was surprised to find out that someone else in the world (at least one...) has the same problem as I have. Only last week I found out by reading this forum that I'm not the only one that have such a problem.
I bought a new Kia Niro on Jan 2017. Unfortunately form Feb 2017 I am dealing with this issue in front of Kia Israel technicians and the official dealer.
If I had to describe the problem - it would have sound EXACTLY the same as what Mr. JosephO described. I have the exact same issue.
Until a month ago the dealer admitted there's a problem and felt the sutter themselves. They connected a recording device to the car and claim they didn't see a thing on the computer. Their claim was that this is a miss-firing problem and following Kia's instructions their solution was replacing the injectors - which of course didn't solve a thing. The car continues to stutter. Sometime these are heavy stutters.
Now they have started to dismiss the issue and decided to blame it on the road conditions and claim this is how that car behaves naturally...!!! On my last meeting with them they offered me to replace the car on an improved leasing deal - which actually proves they recognize there's a real problem in addition to their previous admision to the problem. The more severe issue, is that according to what JosephO wrote, Kia probably had known about this problem and the Kia representatives didn't share the whole truth and told me that Kia had never seen such an issue. This sounds like someone is hiding the truth.
If they don't find a way to solve this to my satisfaction, I will most likely have no other option but to take it to court.
The public has the right to know about these defects and how the car manufacturer deals with its customers. Make your decisions wisely.
If you have a proposal or can share more about such an issue, please respond.
Thanks,
Oded
I have the issue. It is very annoying and I regret having this car. 3 times in the garage and they don’t know how to solve it. Last time they told me it is water in the fuel. They cleaned the fuel tank and system. I got the car and it was stinking of fuel but the stuttering still exists....
Carbon encrusted intake valves
The problem is caused by carbon encrusted intake valves. Gasoline Direct Injected engines have the injectors on the inside of the combustion chamber rather than at the port of the intake valve. The intake valve never gets washed by fuel and no amount of additive added to your gas tank will help. This problem affects many different cars with GDI. The Positive Crankcase Ventilation and Exhaust gas Recirculation gets returned to the intake manifold and it is the carbon from those dirty fumes that build up on the port side of the valves.
Again, port fuel injected engines get the valves cleaned by the fuel from the port injectors, Direct Injected engines do NOT.
its poor casting in the primary engine components. Im going through it on 2017 Niro number two. Been through lemon law arbitration on it once, and Im about to go again. I thought I just got a "lemon" and bought another. Nope, same stuff. Found these photos of a cylinder head on another forum.
Part of my rebuttal to the arbitrator:
I have attached screenshots and photos of internet forum conversations by other Kia Niro (and Hyundai Ioniq – which shares the same Kappa drivetrain as the Kia Niro ) owners. These forum conversations list at least eight owners that have had the same stuttering, jerking, misfiring issues that I have experienced. These are only the owners that experienced these issues and that have come forward online. There may be many more unaccounted in this short survey. One owner in Europe of a Kappa powered Hyundai Ioniq, even has pictures [attached] that show the primary engine components were incorrectly cast or milled at the factory, leading to misfiring and skipping issues. This demonstrates that this is a known issue with this drivetrain. One forum suggests that this issue also may negatively impact the emissions of the vehicle also: “The German Auto Club (ADAC) recently ecotested the Ioniq, Niro, Prius and dozens of other hybrid, diesel and gas cars. It found that many GDI cars, including Ioniq and Niro, failed the CO and PN parts of the Euro6 emissions regulations on their cycle (based on the upcoming WLTP). Ioniq had triple the allowed CO and 4 times the PN. Ioniq scored 5.1 l/100km fuel consumption while the Niro got 5.8. Meanwhile, the Prius passed all emissions rules with ease and got 4.1l/100km. Based on this, the Ioniq and Niro are not ecofriendly and may not even be legal.” I recently owned two Volkswagen Diesels that were affected by the EPA forced buyback. This information makes me begin to question the integrity of these large vehicle manufacturers when it comes to these issues.
Wow, that's pretty interesting. What surprises me is that that head passed QC and was installed on a customer car. I find it hard to believe that those parts are not milled on CNC machines which would make an error like this either ubiquitous or the result of a broken machine. It certainly looks from the photos like that port was incorrectly machined which would definitely lead to running problems.
Obviously the problem is not ubiquitous as if it were every Niro and Ioniq would be showing the same symptoms. I wonder if the problem is limited to a batch or batches of cylinder heads. Do you know the build dates of you current and previous vehicles? Not that that would be definitive, vehicle build date doesn't say anything about when the cylinder head was fabricated.
Very curious. Sorry you ended up with 2 problem cars, that sucks. Good luck getting it resolved.
Sorry to hear, that you have the same problem again.
Do you have links to some or all of the forums where you found all that info. Could be an interesting read...
This is why i always insert a fuel cleaner 4 times a year. I have done this since my 2010 Sonata and my 3 kia's with the GDI system. Even some times, i fuel up with "Super" (1 out of 5) too help it work. Thanks to my mecanic idea for this, i never had a problem since..
Fuel won't clean your intake valves with direct injection. Happy you don't have any problems, but guess what, I don't either without the extra cost. Reasonable for port injection of course. Who knows, perhaps it could help keep your direct injectors clean in a way that the high pressure and ignition cycle cannot.
there is a point that contradict your theorie here
one of you is wrong and I tend to believe Dakota Niro as the fuel (with or without additive) will not clean the intake valve as it is not touching it (direct injection)... I might say that it is a known problem of direct injection (for example I read about it on subaru forester 2.0 turbo)
OMFG.!!! My bad!!....you're Soooo right! man do i am sooo dumb to have been robbed since 2010..,..!! Holy Macaroni! :confused:;)
