ahh, thanksJust press the climate information button to display the temperature in the center screen.
That temperature readout in the driver display is the OUTSIDE/OUTDOOR temperature, the one in the center console after pressing CLIMATE is the temperature that you have SET, not the actual INSIDE / IN cabin temperature......... can dial a set temp. anywhere from LOW to ................not sure,................85 I think? after which it will say HIGH.Currently the only temp readout is in the driver's display. Sure would be nice to have it in the center av display so passengers could see it too.
Should be doable in a sw update.
outside AND desired inside temperature are displayedThat temperature readout in the driver display is the OUTSIDE/OUTDOOR temperature, the one in the center console after pressing CLIMATE is the temperature that you have SET, not the actual INSIDE / IN cabin temperature......... can dial a set temp. anywhere from LOW to ................not sure,................85 I think? after which it will say HIGH.
2018 phev lxWhat year/trim level are you driving? I have a 2017 Niro EX, and I ONLY have outside temperature displayed in that area.
