Did you try driving it for 5-10 minutes?Hello everyone
Yesterday I got this error about tires it said tires pressure is low. I filled up today still light is on. Do you have any problem like this. View attachment 6631
Yes I didDid you try driving it for 5-10 minutes?
Usually if that light comes on you have to drive it for about 5-10 minutes for it to go away. The only thing that I can think of is the tmps sensor is going bad.Did you try driving it for 5-10 minutes?
Bad sensor would also be my suggestion.Usually if that light comes on you have to drive it for about 5-10 minutes for it to go away. The only thing that I can think of is the tmps sensor is going bad.
Before it was 2.1 bar I filled it up 2.3. I got alarm only for right back tireI'm not familiar with it reading in bar, so I can't say how much different .1 bar is. But based on that display it seems the car isn't happy with the difference. In PSI, I believe I have seen the light come on with 3-4 PSI difference.
Hi1 bar = 14.5 psi
2.2 bar = 32 psi seems low. Should be 36 psi?
Bring them all up to 36 psi and see if the light goes out?
It looks like I got confused with bars. I see that it was low in tire pressure. As far as tire pressure, I don't set mines at 36 because it makes my car sluggish. I usually go 3 more psi so my front and rear tires are at 39psi. I know some people will fill it to the max which is 44 psi on the Energy Savers, mines came with the Continental for some reason, it may cause problems.Hi
I did what you told me. Now it is ok. Light go off thank you very much 👍🙂
Were your tires rough in the beginning? When I bought the car the ride was a little bit rough but it calmed down.My tires are also continental and pressure are 36 really it is good no any problems
I just had this happen to me. The warning staHello everyone
Hello everyone
I had this happen. It took a few days to return to normal. It cleared after I took a trip over an hour long.Hello everyone
