HUMMmmmmmm Well I wouldn't do it. Your are dealing with un-sprung weight . (meaning There is no way to support the weight over bumps or dips in the road). The lift will weigh about 200 lbs. for a electric lift and the scooter will weight at least 175 lbs. The hitch will weigh about 75 LBS. All that weight has to sit behind the springs and suspension. The car won't hold that weight and the hitch will soon break or bend the rear of the car. At best it will hang at least 5 inches behind the back bumper.The easy way is to have U-Haul do it. But get the wiring harness from Kia first for a better install.
Relevant threads here are tough to search for but here are two:
Niro Plug-in Trailer Hitch and Wiring
Hi all, Just bought a 2020 Niro EX Plug-in. Love it so far. We need to put a trailer hitch on it (for very light-duty towing and a bike rack), and I've read a couple other threads here about people making a small modification to the Curt Niro hitch to make it fit. That sounds good -- but if...www.kianiroforum.com
niro EV trailer hitch
is there a trailer hitch receiver available for the kia niro EV? is the rear of chassis, where a trailer hitch would mount the same on a normal niro, different than on the EV?www.kianiroforum.com
[/QUOTE
Sprung weight right? Cure is installing higher rate rate springs.Your are dealing with un-sprung weight .
Beefier springs do not address having 350-400 pounds of weight behind the rear axle. Would think that this would raise the front end of the vehicle and adversely affect traction and maneuverability.Sprung weight right? Cure is installing higher rate rate springs.
There is no other way to address extra weight (although in addition to higher rate springs, additional damping is best) and that is what would be the intervention of choice for any vehicle carrying a scooter (or motorcycle or bicycles, tool box, et cetera). Yes, every change to weight distribution changes handling. To which the driver can adjust. This is not a sports car.Beefier springs do not address having 350-400 pounds of weight behind the rear axle. Would think that this would raise the front end of the vehicle and adversely affect traction and maneuverability.
Absolutely true, I had Uhaul put a 2 " receiver on my 2017 ex but no way would I ever put a lift on it , I have A fold up carrier for it and I use Pride 10 Scooter, but because I don't need it all the time I store the carrier in my garage , for long trips I just fold down the back seat and put it inside , and still have room for luggage, safe and dry inside, oh by the way it doesn't even affect my mpgHUMMmmmmmm Well I wouldn't do it. Your are dealing with un-sprung weight . (meaning There is no way to support the weight over bumps or dips in the road). The lift will weigh about 200 lbs. for a electric lift and the scooter will weight at least 175 lbs. The hitch will weigh about 75 LBS. All that weight has to sit behind the springs and suspension. The car won't hold that weight and the hitch will soon break or bend the rear of the car. At best it will hang at least 5 inches behind the back bumper.
I think mine is 10 also. I will see how it fits.Absolutely true, I had Uhaul put a 2 " receiver on my 2017 ex but no way would I ever put a lift on it , I have A fold up carrier for it and I use Pride 10 Scooter, but because I don't need it all the time I store the carrier in my garage , for long trips I just fold down the back seat and put it inside , and still have room for luggage, safe and dry inside, oh by the way it doesn't even affect my mpg
