1 - 3 of 3 Posts
I just noticed a strong high pitched sound coming from my engine, I'm not sure exactly from which component, here is a video:
https://streamable.com/l9465
The car is on in EV mode (Plug-In Hybrid), gear on Park. If I force the ICE to turn on and then off the noise will stop, but it will start again if I turn off/on the car again.
Did you ever hear a similar sound from your car? :confused:
Take it to your dealership, that's either a mis-tensioned belt, a fan bearing that's going, or a dragging brake pedal causing excessive attempts at regen braking.
Update: found the exact component making the noise, if I do lightly press the plastic of the component with a screwdriver the whining noise does change/stop but I can still hear some sort of electrical rattling, so I guess it's faulty.
New video: https://streamable.com/xoq12
It looks to be this part:
1 - 3 of 3 Posts
