I should have written this a couple of years ago!
We bought the Niro in Sept of 2019. Two months after purchase I checked oil level... Way over the full mark. If it's that overfilled this is a problem! Took it to dealer.
Short story is that I discovered that this over-fill reading is incorrect. There must be an edge of some sort which collects a small amount of oil which gets added to the accurate level on the plastic end of the dipstick when you withdraw it. The smooth and round plastic above the Full point comes out with oil from the tip to well up on the top of the plastic; it 'tells" you that the oil level is drastically over-filled.
How did I determine the above?
I had changed the oil using the following test dipstick and exact measuring when changing oil recently; had not driven the vehicle more than a hundred miles since that point, and was certain that the oil level had been and was right at the F level.
I took the one piece flat metal dipstick from my Nisan van's V8, measured an exact length of the Kia dipstick and marked that point. I put a drill bit depth 'stopper' at that point. I used this test dipstick and when I pulled it out there was a small amount of oil on the TOP of a 'half-circle bend' that sticks out from the regular straight metal shaft, which Nissan put about an inch above the full mark. At the 'qt. low ... Full' marking the oil level was at exactly F. The inch between that point and the bend had no oil on it. Thus, the oil on the grid between Low and Full was from it’s immersion into the oil in the pan and the bit on TOP of that sticking out half circle must have come from above.
Next I will be searching for any all metal dipstick whose ‘handle end’ fit’s the Kia’s opening with a length exactly the matching length of the one Kia put in my Niro!! Shouldn’t a $26,000 vehicle have an accurate dipstick?
If anyone knows of a non plastic tipped replacement please let me know!
I hope this helps someone
Rod House
Rod House
